New WoodChat!
leather adhesive
leather adhesive
Jack Guzman from Maine
leather adhesive
I attached leather to the mating surfaces on my new shavehorse. I glued it on with some spray adhesive designed for sanding discs. After a couple days I started using the horse and the leather started to slide and bunch up. I removed it and cleaned up the adhesive. Before I try something else I thought it might be smart to ask for advice. I was thinking of using contact cement. The stuff that comes in a can and is used for attaching laminates to countertops. Will this work? What do others use? ---Jack
Re: leather adhesive
TomD
A lot of stuff could work. There are many different types of leather, but assuming you are not using something that is wax impregnated, many glues that will work with wood also work with leather. A foolproof option, and a generally useful glue to have around, is Barge cement. Some hardware stores, Tandy, shoe stores, and fly fishing outlets will have it. It is both good at bonding to leather, and completely waterproof. It is a contact cement.
Many glues work with leather, some of the whitish glues, like weldbond will work. CA, epoxy, fish, hide, Yes paste, etc...
Thanks Tom. I never even considered hide glue.I think I'd much rather use that than contact cement. That stuff stinks and it's unforgiving if things aren't lined up just right. I always get it on everything too. That spray adhesive was a messy operation too.
The leather didn't have any wax in it.The glue stuck to the leather just fine.It just never dried up. The leather stuck to the wood but it slid when pressure was applied to it by pulling on the drawknife. I think that stuff stays tacky so you can replace worn sanding discs attached with it easier.---Jack
Patrick Gibbons
I attached leather to the cheeks of my vise on my bench back in 2001 with contact cement. They are still attached and in place ten years later.
Re: leather adhesive - Barge Cement
Bill Tindall
that is what the person that does my leather work uses.
My sister works with leather and she also recommends Barge. I have none though and neither does my local hardware so I'm going to see what hide glue will do. There is a bottle of Patricks right on my bench. The only downside is waiting for it to dry.Thanks for all the responses.---Jack
Stephen Shepherd
Hide Glue
Howard
I use Titebond II with no problems
Done
I used Patricks old brown glue and it worked just fine.After only an hour to dry I shaved four spindles without a problem. Funny I never thought of it.I use the stuff every day. I love this stuff. It's so easy to work with. Easy clean up with warm water on a rag.Try that with contact cement.---Jack
