handmade reamer from saw blade
jimbo
Somewhere i have seen several articles on making a tapered reamer from saw blades, but cant seem to find it in the archives. Can someone give me a direction? Thanks, j. smith
jimbo
Re: handmade reamer from saw blade
Mike in Suffolk Virginia
Try this link: http://www.greenwoodworking.com/SawSteelTaperedReamerPlans
partial answer
Bill Tindall
I made one and can post a picture if no one else can link you to the Article that best describes how to make and use it. I can't recall how I found it. BTW, don't expect a miracle. It didn't work all that great in a hard wood, but it did work to taper some blind leg holes in stool.
TomD
Yeah it is on John Alexander's site. The main thing is to get a blade. Then you fashion a same taper dowel, then you saw it down the middle, and insert the blade, just shim it higher if you don't initially get enough projection. The blade is just in there, it does not need anything to hold it in, since the pressure form following a hole does just fine. I use a zip tie when I want the parts to stay together.
I followed the advice of sharpening it, and leaving the teeth sharp. I found mine worked really well and preferred it to the very high quality Emhoff one I had. But the better metal ones, the metal cones, with a notch cut out, are highly steerable, which makes getting onto the right angle really easy. The best way to use the Alexander one is pretty much centered in the pilot.
I found getting the right blade a minor task, at least when I built it. It seemed a lot of these things were being made in a Japanese style, and I worried about whether the teeth would take the side loads, and they would not be as easy to sharpen in this particular use, I feared. Also, it is ideal if the taper is something easy to calc, since it makes making tenons easier. The blade I eventually found was 1/8" taper to the inch.
jimbo
Gents, thanks for the input. all the info is helpful in taking the steps for making the beast for my application. Jimbo
TomD
Good luck. I made mine at my summer home, and I only had some firewood, and spokeshaves, etc... Still turned out great. So it isn't the kind of project that requires a pattern makers lathe, and stereo magnifiers to get right.
J.Bodin
The youtube video is Curtis Buchanan (Windsor Chair Maker) drilling and reaming holes , using the reamer you are looking for, in a windsor chair seat. He has a series of youtube videos making a windsor chair from log to finished product. In this video he shows how he drills and reams the compound angled holes. http://www.youtube.com/watch?v=zrlWcQ4sKYc
