New WoodChat!
what size gennou *LINK*
Re: what size gennou *LINK*
Pam Niedermayer
It's pretty small, probably somewhere around 250g/half a pound.
Pam
Bruce, a MN Galoot
Thanks, Pam. Is that a reasonable size for all-purpose chisel whacking? What do you use?
Pam Niedermayer
I would say that 350gm is better for all purpose use; but I often use a 900gm honey for plane making and a 200gm or so wooden one for adjusting plane blades. OTOH, lots of the time I use a spare dai blank for both those tasks.
Hard to disagree with Derek on his list, probably much better thought out than mine. :)
Pam
wilbur
Derek's list is definitely more thought out than mine. I use a 375g gennou for everything: general chisel whacking, mortising, plane adjusting, etc.
When I was chopping out the 1" wide mortises for my workbench, I used a different hammer: a 16 oz. framing hammer from the borg. :D
Bruce, a MN Galoot
A 1" mortise would need a little more persuasion than a 375 gm hammer, a little more authority.
What I use for an all-purpose chisel whacker is a 1lb dead blow, so I thought a gennou might be good to try. I figured if it's good enough for the man in the video... He sure doesn't need much by way of gauges to measure his dovetails, does he.
900 grams?
That's really getting in touch with your inner John Henry!
Thanks all
Bruce, a MN Galoot
the 375 gm gennou from Hida will go on my Christmas list (although I really don't want anything, people keep bugging me about having a list). Lacking my own experience, there's nothing better than someone else's. :D
Or Flanders and Swan...
John in NM
As far as I remember, they wrote and performed the original "I'm a Gnu" song :D
Re: 900 grams?
Pam Niedermayer
:) You bet. But I tried using 450 gms and it took forever, very tedious when fitting a blade in a plane. Mark with graphite and insert. Mark with graphite and insert. Mark....
Pam
Didn't he make Pinocchio?
Happy pounding.
What's gennou?
Jason in OC
Nothing, what's gennou with you?
Schtoo
Looks like 300g to me. Just a tad too big for the 200 ranges.
I use 300-375g for most stuff. Anything bigger, mallet comes out. Adjusting planes, mallet only.
But what do I know?
Stu.
(Tucking the hammer maker's catalog back into the drawer. I get to order from that in the new year, no earlier...)
That's "snu"
Bruce, a MN Galoot
as in what "snu" with you?
david weaver
I generally adjust my mosaku with any hammer I have handy, sometimes it's one with the face a bit chewed up. Same with the inukubi plane. And the yamamotos.
I'll belt sand the backs and crown of the iron if they get too mealed up (the back) or start to roll and split (the tops of the irons).
Snu?
Bob Hackett
I thought Snu was that guy that imported those tools from Asia. ;)
And I thought it was one of the plurals of "snow"
TomD
Back in the early 80s when Robert Meadows brought the craftsmen from Japan. I saw a plane maker making 1/2" mortices, and he was using a short handled sledge, probably about 2 pounds. I mostly use a 14 ounce hammer, when I used to use the Japanese ones. I find the urethane ones are a lot quieter, and have more of a dead blow. I didn't want to make the move, but that's what happened. I use a 20 ounce one of those for most NA hardwoods.
He seems to be working Paulonia, which is about the hardness of balsa, or red cedar.
