We value your privacy.
Any ideas where I can get a decent framing square that is actually square? I bought what I thought was a decent one at a local store (not big box) and it is about 1/16" out at 24". I am using it for cabiet making, but can't afford to spend an arm and a leg.
I took an old no-name square that was a little more than 1/32" out of square on the short leg and made it so close to perfect that I can't tell the difference.
Take a sheet of plywood or something with a known straight edge, lay your square against it and make a mark with a knife with a very fine line. Flip the square 180 degrees and see how it measures up.
You can open up the square by tapping on the inside of the angle, the point where the two legs join, with a ball peen hammer. Hit the outside of the angle to close it up. It might take a while, but tapping will move enough metal to make that sucker perfect, or as close as you can get it.
I use a center punch. Both methods are the same: draw out (thin) the metal as needed.
Make sure you use the same edge - outside or inside of the beam leg (long one) while you're adjusting the square. Then check the other edge of the beam to see if it's parallel. If not, I don't think there's any other solution than filing the offending edge.
After that, if you use the square for inside and outside angles both, you'll want to hold the beam against the known straight edge and check the short leg for parallel, filing as needed.
Lee Valley sells a square, for which the catalog copy cites an accuracy of 1/17th of the degree on the outside edge; you'd have to check with them to see if there's a similar accuracy guarantee on the inside edge. Linky below. No affiliation with Lee Valley except for being a frequently happy customer.
I had less luck with the hammer but a pointed punch will open or close one readily.
Randy, this is an easy operation unless you screw up and bash the square on the inside when you want to close the angle ( I will not go into details as to how I know this but it may have something to do with the fact that I have punch marks all up and down the square).
I have that Lee Valley square and it was pretty far out (and not in a good way) but the center punch trick worked really well. The legs were parallel however. Other than that, it is a really nice square.
It takes a bunch of small whacks to move the metal. But when it starts it'll happen fairly quickly. Sneak up on the final adjustment; don't try to get there in just a few big whacks.
I have a nice old Craftsman aluminum square (won't rust) that is dead nuts on, so I don't need one. If I was looking for a new one I would buy the one in the link below (you can purchase Starrett tools from MSC) and then send it back if it isn't square. I too have read about adjusting carpenters squares to make them square, I've just never actually believed it would work.
I have the Lee Valley Stainless square, and it is spot on. I used it for quite a bit of timber framing. One still needs to know how to adjust them since dropping them can knock them out. Stainless tends to be less ductile, so it might stay in square better, and prove a lot harder to bend. It is sure a lot harder to bend stainless pipe. Which is odd because it has poor strength, and yield numbers. But it work hardens.
The square is probably fine but I find the new Starrett website a step back. I could find more facts on the old one. The first time I logged into the new one I was asked to take a survey and x'ed out and haven't been able to get the prompt again. And I didn't take the survey so they don't know how I feel about the new website...
"And I didn't take the survey so they don't know how I feel about the new website... "
I bet you could e-mail them; I've had occasion to e-mail their customer service once or twice, and they were pretty responsive, about 2 to 3 on the 1 to 10 scale (with Lee Valley's people, who darned near crawl over the wires into the house in their eagerness to be helpful, rating 1).
Yeah, and they stay square. I have one probably going back to maybe 1979 that was my first slip joint. Pretty much the same as the day I made it. Warm to the touch, not normally shifted by being dropped on a concrete floor. The corners take a hit, but the squareness is probably OK. I remember the lengths I went to to get a Rabone Chesterman rule accurate to .001 over something or other. Turns out to be a degree of accuracy that a plane can easily enough produce. Still use that rule though.
