New WoodChat!
Roubo winding sticks
Warren in Lancaster, PA
I have looked at this Roubo Planche 14 for many years.
I thought the winding sticks had feet so that they could bridge over a hump in the rough stock. However a closer look shows that they sit in shallow rabbets at the edges of the board.
It looks as if he first of all made a shallow rabbet on each edge, then checked with the winding sticks and adjusted the rabbets until they were in the same plane. This gives a guide for flattening the rest of the panel, just planing until close to the rabbets. It also would help with traversing because the far side would be protected from breaking out. Here is a fillister from Roubo, Planche 20.
Re: Roubo winding sticks
Stephen Shepherd
Excellent research
Clever!
wilbur
That's a really acute observation. Send it in to Chris Schwarz!
Hi Warren
That is a clever design, not only a very useful idea.
At first glance I thought "you would need a different size winding stick for each width of board". But then you can see that they are adjustable for width. Clever.
The idea is to plane a rebate along each side. How would one go about this in practice if the board is twisted? Rebate one side, use this as a reference side, then plane the other side until the windsticks are level?
EDIT: Duh! You described this is your post.
bugbear
Interesting - that's extremely close to normal practice - for stone masons!
BugBear
Good eye... really, really good eye.
James Watriss
Roubo's funny. I remember writing to Chris Schwartz about a panel a few years ago... there was a pedal with a length of rope hooked up to pull in the jaw of a leg vise. Basically, to hold the jaw in place while you adjusted a board, before you clamp down with the wooden screw.
He said he probably didn't have that volume. But I know I've flipped through mine many times, and I see new stuff all the time, so I suspect he probably has the volume but missed that particular detail. I think it's just a question of being open to what you're looking at, but either way...
Good eye.
