Answer.....
Bill Tindall
Following the heading "Task at Hand" there follows "nibbling the length of the bull nose molding facing for the chest of drawers".
The blades are not being veneered, rather a bull nose molding is being applied to (1) cover up the dovetail joinery and (2) to bull nose the forward facing case edges as a design element. This detail will put a modern twist to an otherwise Federal-looking case.
This edge of the case side was bull nosed then a thin strip including the bull nose was ripped from the case side with a very narrow kerf blade before case assembly. Now it is being reapplied with additional strips to be applied to the blades.
I could add that it is a great relief that all the dart cut-outs for the blade molding stayed lined up and the bottom of the applied strip mated perfect with the base molding. Situations where there are no "degrees of freedom" in a fit are stressful for me and I proceed deliberately with the execution. Using a 45 degree jig block I will nibble away at the darts on the blade molding until I get good fits, but in this case I have extra pieces made if I screw up a fit. Gluing back the case edges that were originally ripped off in the beginning left no room for error. There aren't extra pieces....that would match grain and color.
