New WoodChat!
stack of drawers
stack of drawers
stack of drawers
Bill Tindall
Finally have the drawers ready for staining. Deer hunting has been interfering with progress.
For some complicated reasons the surface of the veneer for these drawers had deeper machine marks than the usual surface I get from the planer and bad luck struck and my air driver orbital sander took ill. Nice weather is becoming less probably and I need to have two nice days out doors to get the everything sprayed. Desperation drove me to the hand plane. Unsure of its current state I resharpened it and with some trepidation I began to smooth the drawer fronts.
At once I ran into one of the reasons I avoid hand planing surfaces when possible. There was a slight concave bow to each drawer which meant the wide #5 1/2 plane iron would not engage the middle of the drawer until the edges were lowered to bring the surface into a uniform plane. It brought to mind the recent plane iron width discussion. I was sweating by the time I finished one drawer. Thankfully STS (sudden tearout syndrome) was kept at bay in spite of the fact the wood was subtly figured.
The resulting surfaced looked bright and smooth and I would have applied finished without further refinement if I was not going to stain the piece. However, staining the planed surface with a pigment stain would have resulted in a too dark and blotchy appearance due to the open pores and micro-tears where there was grain reversal. But, planing had accomplished what 100 and 120 grit on the ROS would have ordinarily accomplished and done so with relative ease, given that STS was avoided. I finished the surface preparation with 220 garnet making sure there were no dull places where the dust was trapped that would indicate micro-torn grain. Failure to remove these areas leads to the dreaded blotches.
I still have the face molding to apply(tedious) to the chest of drawers and I will be ready to begin finishing. I will likely varnish this piece. I have become fond of the warm appearance of an aged varnish finish.
Re: stack of drawers
really nice, and thanks for progress report *LINK*
I must say, though, that "Also Sprach Zarathustra" was running through my mind, even though it's not quite a monolith.
See link below if you're not familiar with the music.
From "2001, a Space Odyssey"
Pam Niedermayer
Too late for this project (looks great as usual), but can I send you a spare coffin smoother, much better for the job?
Pam
Hi Bill
Those drawers look very clean lined, nicely dimensioned, and well made. An imposing monument!
This tearout fear of yours can be dealt with by one of the following:
1. Bring the drawers over to my place, and we will use my Marcou or SBUS on them.
2. Send the limo over to collect me (Saturday morning is best) and I'll bring a few handplanes along to your shop.
3. Have you tried a cabinet/card scraper yet?
4. That SBUS or similar high-angled small smoother is ideal for planing drawers.
I'm hoping to finish the cases for my drawers this weekend. Perhaps I may have a chance to post a monolith as well.
Transportation
"Send the limo over to collect me (Saturday morning is best) and I'll bring a few handplanes along to your shop."
I'm not sure the highway system extends that far, in spite of the fact, as George Carlin pointed out, that the American interstate highway system includes highways in Hawai'i.
Nice stack
Frank D. in Montreal
Can't wait to see the finished piece.
One trick for planing concave surfaces is to skew the plane. You can do this rather drastically and plane on a little bit of a diagonal to skew even more. The effective blade width is reduced so you have to take more passes, but the sole length is shortened relative to the board length, and you can cheat enough to put a concave radius on straight boards (or plane concave boards lengthwise with a flat-soled plane). I use this trick to match trim with curved walls, or to plane wood that's been sitting around too long after milling.
FWIW
Re: too risky!
Pam Niedermayer
I'm pretty sure you'd love it. Email me at pam@pinehill.com with your address, so the next time I come across a coffin smoother (might be a month or two, shop is still in transition), I'll ship you one. Maybe will include a little Japanese smoother/polisher with it.
Pam
Re: too risky!
Pam Niedermayer
Oops, as Rick would say, I remembered I still have your address in the Wool Pads deal.
Pam
Re: Transportation
Bruce, a MN Galoot
I'm not sure how to get to Australia from Japan, but Google will give you driving directions to Japan. Well, not quite. According to the instructions you have to kayak across the Pacific.
That's really nice work, Bill!
Bruce, a MN Galoot
If you're not careful, you'll slide down that slippery slope yet :D
then you have to Kayak to Oz
