We value your privacy.
I'm restoring a #5, but one screw refuses to come out. I may have to drill it out, but I seem to recall that Stanley used its own size of screws, not standard size screws. If so, I don't have a tap that would fit. Is this correct? If so, any suggestions?
Stanley designed its planes during a period when standardization of screw sizes and pitches was nonexistent or in its infancy (depending on which plane). Some screws are of sizes/pitches that became standard sizes; some (maybe most) are not. About the only good news is that they were then fairly consistent, not changing screw sizes much. Which screw is misbehaving? If you can specify that, either someone here will know the size/pitch of the thread or one of us can measure it for you.
Suggestions: If you've got access to a propane or MAPP torch (or gas welding torch), heat up a piece of steel rod, say 3/8" diameter, and touch it to the head of the screw for 30 seconds or so, then remove. Don't do this if the screw in question is holding the tote or knob or any other wooden part. This will often break loose the corrosion in the threads.
If you've been using WD-40 as your penetrating oil, see if you can find Kano Kroil or mix up a 50/50 brew of automatic transmission fluid and acetone. Either of these has proven to be a better penetrating oil than WD-40.
If you can support the plane casting in a way that you are absolutely SURE you won't break it with this approach, set the correctly sized, plastic handled screwdriver in the screw slot and strike it a firm blow with a moderately heavy hammer. Again, the shock will often break loose the corrosion. This particular trick always scares the heck out of me when applied to the fairly thin casting sections on a plane, so I use it only when I've given up on other approaches.
I had a recalcitrant set screw and a maintenance man told me to flood it with good penetrating fluid, set the driver and whack it smartly. The suggestion struck me as preposterous, so it became the last thing I tried. It worked as if by magic.
I suppose the shock makes a micro crack that enables the penetrating fluid to penetrate the corroded interface. In any case it is now the first thing I try.
I have done this one time and it worked. I placed the plane body, everything elses removed, in an oven set at 450 and let it get hot. When it was hot I poured break fluid on to the screw, a lite tap and the screw came out. I was given this trick by my father inlaw who used it on old farm equipment, cars trucks etc. I have used it on other things useing a torch and it has always worked when everything else failed. I used an oven for even heating to avoid warping of the plane.
Hadn't thought of the oven treatment. I may try it later. Tried some of the other ideas, but no luck. I put the plane back into electrolysis and walked away.
