New WoodChat!
Wooden Plane Wedge Question
Dave (Arlington, VA)
I picked up a 22 inch traditional wooden handplane (Razee) a little while ago at a flea market. It was in excellent shape and had a very thick blade (and chipbreaker) which I thought could help me practice my freehand sharpening skills. The only problem with the plane was that it was missing its wedge.
So, I'm making a wedge right now and I don't have a good template or model to follow. My main question is how thick (or thin) should the wedge be at this thinnest point down at the bottom of the wedge? One-quarter inch? One-eighth inch? One-sixteenth?
Also any other tips in wedge making would be gratefully received.
Thank you!
Dave
Re: Wooden Plane Wedge Question
John in NM
Since no one else has answered yet, I'll throw something out there. Should bring the experts out of the woodwork to correct my "wrong" answer :D
Wedge only needs to be as thick as the bottom part of the side cut it fits in (no, I don't know the proper name for that cut :D). Most I've seen on wide planes have a deep crescent cut out where the bulk of the shavings will pass, so that the shavings don't hang up on or under the wedge. But bear in mind, old tools are a bit scarce out here, and they tend to have lived a hard life, so I've not seen a huge number of larger wood planes.
Here's a pic I found on the web, shows the kind of wedge I'm picturing from your description. The relief cut is not a crescent of course, I must have seen that on some fancy whittled plane.
Jack Guzman from Maine
These are some wedges I have on hand. The one on the left is one I made of cherry for a handled smooth plane. The center one is from a razee fore plane.It is shaped similar to the other two on the other side. The groove is for clearance of the nut on the chip breaker. The other one is to a coffin smoother. These are typical of most I've seen.---Jack ( I hope the pictures worked)
Bob Hackett
I usually rough cut the wedge and then tune the fit of the taper so it fits well between the abutments (the tapered grooves on each side of the blade when it`s in place) and the top of the iron or chip breaker and iron if the plane has a chip breaker. The taper will go from a sharp edge nearest the mouth of the plane to whatever width/shape you feel is most appropriate at the upper end and still allows you to hit the wedge with a mallet to seat it.
Once I have the iron secured(I find graphite from rubbing a pencil on the top of the iron and inside the abutments helps mark high spots that need to be removed) I then try the plane out by making a heavy cut to be sure the wedge will hold the iron while the plane is working. The chips will most likely jam the mouth at this point but this is part of the test. If the wedge and iron stay in place and nether moves then I just remove material from the wedge between the abutments until the chips don`t jam up anymore. You will usually end up with two remaining "legs" on either side of the leading edge of the wedge at this point. these legs should fill the abutments yet not protrude beyond the mouth of the plane (obviously the plane will not cut a fill width chip if they protrude). These legs hold the iron securely close to the mouth where the cutting is taking place (See Jack`s pics for examples of these leading "legs"). You may want to taper the legs toward the abutments to allow a wider path for the chips to escape but don`t remove them entirely or the iron may begin to move laterally when in use.
There are many excellent books out there that cover plane making and repair . Authors like Dunbar, Pierce, Hack, Whelan and others cover wedge fitting in depth in their books. I would recommend reading at least one of these books about making abutment style planes (as opposed to planes that use a rod to hold the wedge) before undertaking this task. It`ll be time well spent and save you a lot of trouble and wasted effort.
Hope this has been of some help.
Thank you, John
John -
Thank you. That pic looks alot like my Razee...except that mine has a shorter blade, a recessed back of the body and might be in a bit better shape.
I appreciate the encouragement and the pic. I suspect the wedge on this plane is not original.
Dave
Thank you, Jack.
Jack -
Thank you for the pics. I ended up doing a wedge much like the one you have pictured on the right. It seems like it is working fine. Time will tell. I will likely keep tweaking it with use. I have been surprised at how much "deeper" the wedge sets with a few taps of a small mallet.
Your note encouraged me to keep at it. I appreciate the help. Thank you for posting.
Dave
Thank you, Bob.
Bob -
I really appreciated your description. This afternoon I followed a process very similar. Things seem to be working out well. I didn't do the graphite -- but the blade seems to be holding fine and there's not chatter (even though it is not very sharp).
I did notice (which I didn't at the flea market) that there is only about 1/8 inch of useable blade left. While that doesn't sound like much (and - really - isn't much) I am only a woodworking hobbyist and at my rate of work - just ask my wife :-) - it will take me a long time to go through 1/8 an inch of a 3/16 inch thick blade -- assuming I don't gouge big chips out of it.
Still I can't help but wonder if that not the reason the wedge wandered away. My new wedge has to be pretty short to still leave room to tap/adjust the blade. If the old wedge was of more standard size (and hadn't been modified) I think it might have been hard to adjust this blade. Though the plane is otherwise in good shape (and unless the blade is not original to this plane) the size of the blade suggests this plane saw good use.
Thanks for the advice and encouragement to get this plane back in working order.
Dave
TomD
You make a full size wedge, and then trace lines on it from the abutments. Then you trim out the center and give it a good secondary ramp to help smooth the passage for the shaving. Study the tips of the wedge, and the throat of the plane and carve away the tips as required to get rid of any excess in the tips that might catch shavings. One can also carve the tips to direct the shaving up the plane. Of the antiques in my collection this area seems to vary the most, so not every wedge would work as well in every plane, even if it fit well generally.
One thing I like to do, it fit the wedge too wide. Then I rough cut out the center area. Then I take a shaving from each side so that the main body of the wedge is relieved, but the points aren't. This allows the points to have mild spring like tension on the sides of the plane, and makes for a neat job, and less snags for the shavings.
Pam Niedermayer
How do you do this? Seems that to trace this way requires you to trace through a piece of wood.
Huh? A too-wide wedge wouldn't fit at all.
Please tell me what I'm misunderstanding.
Pam
TomD
You're misunderstanding. Well my work is done! :)
I don't understand the first question seems obvious when the parts are together.
The oversized wedge if you follow my instructions, is reduced in the solid portion, and is only wider in the points. This creates a sprung wedge where it hugs the sides with mild pressure. This is not a spliting load, just enough to keep the points orderly. If you have experienced the reverse, maybe with an antique, where there is a gap that snags shaving, the desire to go a few thou in the opposite direction would seem reasonable. There may well be a better way to get this result. Waiting for the C+W video.
OK, understood, thanks.
