New WoodChat!
A55 Smoothing Plane
rusty hand plane
rusty hand plane
rusty hand plane
darrin hill
i got an old stanly #7 for $10 at a flea market and want to clean it up a bit...
dont want it looking like out of the box, but it does have some rusty screws..
what can i soak it in to remove rust and the few paint chips on it? i've used wd 40, but just checking other options..
Re: rusty hand plane
I use white vinegar, soak for 24 hours. Some folks use citric acid - similar concept, a little more work to get it. Still others use a product called EvapoRust.
Sometimes plain old mechanical removal works, too, depending on the particular job. You can get brass wire brushes in the paint aisle of your hardware store.
Whichever, if you use a soaking product (vinegar, citric acid, etc.), wash it off thoroughly and then apply WD-40 enthusiastically; let sit, wipe down. This will forestall new rust. I like to wax every surface I can on the plane except the cutting iron.
scott grandstaff
scott grandstaff
Get waterless hand cleaner and get to work with a cloth and nylon brushes.
On bare iron you can use a little green scrubber pad if you have to. But it sounds like you have a pretty clean plane already.
When its all clean and dry again, wax it. Good old fashioned Johnsons paste wax (258 million housewives around the world for 75+ years were not wrong).
yours Scott
TomD
Another option is the old battery charger method.
http://www.stovebolt.com/techtips/rust/electrolytic_derusting.htm
JMOHNIKE
Over the years I have cleaned up 100 or more had planes. The only screws that I have ever had a real problem with are the ones holding the handles. It seems as if they are made of a poor quality metal. Any of the others usually only requie a lite tap with a screwdriver an a mallet and they will loosen. I wire brush all the rust off useing a dremel for the inside. The paint is another issue, as just about if not all of the paint is a Japaned paint. Very hard and I have not found a remover that works, possibly someone else has. I will rub the bare metal down with rubbing compound several time, and then apply a coat or two of auto paste wax. I like to make them look as new a possible. I think they are pretty with the new paint, polished wood and brass.
good luck
Bill White
Sure don't wanna start a war here, but I don't use auto wax. It contains silicone which is BAD STUFF on wood that will possibly be finished.
Bill
JMOHNIKE
Bill I agree it can be bad. However, in my experience, the majority is rubbed off after the first pass or two. Any thing that is on the wood wil be removed with additional passes or during the sanding process. I have had more of a problem with dusting sprays which have been applied to a damaged finish. These are liquids which penitrate the surface. The wax residue on the plane is a dry coating. Thanks for mentioning it.
