New WoodChat!
Davis Mantle Clock Inclinometer
scott grandstaff
scott grandstaff
Some months ago I was talking to Jim one day.
Jim Thompson, the old Millrat, my friend.
Hey, how would you like a Davis inclinometer level? he sez.
I got one from a yard sale and I am not going to repair it.
I am thinking, this can't be what I think it is. I was sure it was something else, but I love levels anyway, and of course I was interested.
I opened the box and sure enough, the incredibly rare Davis mantle clock was looking right back at me.
And except for the missing vial, it wasn't broken anyplace.
It had been, however, actually buried in the ground for years and years. Not a trace of paint and the screws had no heads left and it was totally crunchy with thick hard rust from one end to the other.
I never really thought it could be saved, nobody would.
But hey, who has more time than me? And besides there is no way I was ever going to see another.
This picture is one that Jim took, I think he needs to work for Playboy, it looks a -lot- better in this pic than it did in my hands.
So I cleaned what I could without scratching the delicate patina of the face brass, and plunked it down in a bath of automatic transmission fluid and acetone. The best penetrating oil for the least money, by far.
Plunked it right down it a plastic tub I had a cover for, and left it for three weeks.
This basically did little though. The iron body had blooomed with rust that welded the brass to it (clearance is tight anyway). The screws were solid frozen and none of the little screws on the face had any trace of slot left, they were just smooth. The little pointer was merely a trace of rust where it had used to be.
So first I took a hand impact screwdriver. You know, you swat it and it delivers impact in a small way? I took one of those and began to work the long locking screws. I cleaned the slots with dental tools first. Made a wooden support structure for the level, (so fragile),
and began hitting the driver.
I would hit a while and dribble more penetrant and hit more etc. It took about a week of this on and off to finally get one to move. If you hurry, you die, and there was no second chance with this rarity.
Finally got both of them out!! Out!! It was unbelievable.
But it didn't help me a bit. The brass was still frozen to the body just as tight.
I had no idea how it was really supposed to come apart, but I knew the tiny screws were holding something. They had to go.
I needed Peter Mc's hands and eyes!! And his best Foredom!
But mine would have to do.
It was pretty much like tap dancing on jello while trying to hold a greased bb in your butt cheeks. On slip and you're gone.
My best glasses and my best tool and disaster lurking every second.
I slowly cut off the heads of the screws until the last traces were gone.
Still nothing moving. Still frozen solid.
There was nothing left but to build another holding fixture and take a soft piece of copper and begin to hammer the parts apart.
I couldn't just pick and spot and pound, it all had to come loose at once or it would bend.
So I walked the punch around and around, overlapping each time. Around and around.
It took 3 more days on and off. I would go until tired (slopping more oil often) and stop. I knew I had to be alert for this.
Finally after all this, a tiny movement. Eureka!!
But now it was more dangerous than ever. Now it had to even out so I started just one side overlapping and tapping, until that moved too.
First the outer ring, then the center section.
It was free!!
Putting it back together was not so hard, except the one little chore of drilling out the stubs of the tiny screws, and retapping the holes back to size 2-56 !!
But I had the drill and tap.
The body was stripped and prepared for finish. Citric acid and soft brushes mostly until it was finally clean.
It got coats of baked japan. None on the bottom of course.
That was scraped for accuracy.
The brass was only cleaned where the sun don't shine. I wanted that rich patina!! The vial was replaced with a period vial. I had one from another broken level of course.
Follow up edit of omitted details heehehe
Yes the iron was pitted pretty bad in places and not so bad in others. I had to take a file to the flats on each side of the topside, also the big arc above the main screws. Its still kind of bad on the sides under the screws, but it wasn't as bad.
Some of the cove molding was scraped 1/2 way smooth again.
Light sanding to smooth everything.
This is why the japan is so thick. heehhehehe
Luckily the base was maybe the least pitted! It still shows some after the scraping but not too bad.
Did you know a normal hand/card scraper does cast iron just fine? Its just a slightly different technique of working. Messy, like spraying a lock in graphite with the greasy black clinging dust everywhere, but not that hard to do.
The screws are the same size and head type as the originals.
The pointer is smaller than it looks in the pictures!!
It took one trial run and then 2 honest tries at it, to get what you see.
I had a fancier pointer in mind, but who are we kidding? Its tiny!
(the guys who made watch hands were insane)
If you ever need, the trick is to drill that hole first! Shape the part around the hole, you will never get the hole in the middle otherwise.
The screws and pointer were fire blackened with a torch, then rubbed a little to simulate wear.
yours Scott
Re: Davis Mantle Clock Inclinometer
Oh my
I'd be speechless, except that, if I were, you'd never know how impressed I am. That is lovely beyond lovely. The tool gods are smiling down on you for saving that one.
A wonderful gloat...
... and a riveting play-by-play on the restoration, not to mention a beautiful job. You definitely hit pay dirt.
Bruce, a MN Galoot
That's a once-in-a-lifetime find, and an equally memorable restoration. You did good!
penetrating "oil"
Jerry Gibbs
can you tell me more about the mixture of ATF and acetone? nice job on the restoration.
Whats that sound ?
scott grandstaff
Re: penetrating "oil"
scott grandstaff
Its the same as any other "snake oil" penetrating oil (and I have tried them all), its just cheap.
If you are a hard core cheapskate, you can filter used tranny fluid and mix a little acetone in (you have to pay money for acetone, and besides its a pretty aromatic solvent, so I use like, 20% ace)
Well its almost free.
I like a pump oiler and a flexible spout oiler for application, besides a dunk tank.
yours Scott
