Machine aided dovetail waste removal
Bill Tindall
Andrew alluded to a router(trimmer) technique that I didn't understand. It sounded unduly complicated by involving setting up a fence. (It is entirely Andrew's fault that machines have crept into the Hand Tool Forum.)
I fix the drawer front back side up on the bench. Set a 1/4 or 3/8" straight router bit exactly the depth that the tails are long. In a series of clockwise arcs starting at the right side of the waste, route away the waste to near the saw lines, and base line. With good lighting I route free-hand to within 1/64" of the base line and about 1/32 to the saw line. I bought a new light weight router with LED lighting just for this task, and hinge mortises. A sharp bit makes this operation go smoothly. I understand the Lonnie Bird shop teaches this technique.
In the Headley shop they remove the waste with a hollow chisel mortiser. A fence is set up to locate the mortise exactly at the baseline and the depth is just shy of the tail length. This approach has the advantage of leaving long grain to pare to get the tail depth perfect. The disadvantage is setting up the mortise machine fence. However, they always use the same drawer thickness so the fence set-up can be made quick. I don't have a fence arrangement that is quick to precisely locate or I would use this approach as it avoids end grain paring to the baseline for the drawer thickness.
Personally I am not wedded to hand tool dovetail waste removal. I regard it a tedious task to be minimized. I route out the half blinds and band saw away the through dovetail waste. A band saw can be used as a micro-chisel and waste removed right to, or very nearly to, a scribed base line (again a Headley shop technique).
