New WoodChat!
Gluing drawers in place question, Andrew?
Bill Tindall
Did I understand correctly that the drawer is not fully closed in the case during the glue curing time? Is this detail to preclude the risk of the drawer gluing itself to the case, or some other reason?
I have been capturing a thin piece of plastic between the frame and side of the drawer front where there could be a thin film of unhardened glue. These two strips also center the drawer in its opening. Do you do any wedging of the drawer in the back to center it in the opening?
Re: Gluing drawers in place question, Andrew?
Just straight in, Bill
Andrew F in Australia
Hi Bill,
No plastic, just make sure that there's no glue left on the outside of the drawer.
Yes, it's left proud of the opening but parallel to the drawer rail so that you don't glue it in.
I just press the drawer up against one guide to ensure that it dries parallel to the opening.
CHeers,
Andrew
question
Bill Tindall
How long do you leave a drawer to "cure' before you feel the glue is sufficiently cured to do fitting(by planing)?
Time depends on the glue, Bill
Wait until it's gelled completely on the outside. Anywhere before two and ten hours, depending upon the ambient temp.
Of course, 24 hours is better. Rarely are you in that much of a rush.
Cheers,
Andrew F
