Preparing drawer sides in pairs
Bill Tindall
In our ongoing discussion of drawer preparation there is yet another variable, whether to do the sides as pairs. It is a technique I picked up from a professional shop. I find it it nearly halves the time to make the sides with no disadvantage I have found.
The rough cut sides are nailed together with two nails on diagonal corners which keep the pieces from moving during subsequent operations. I find the brads from a brad nailer hold better than round brads. Then the pair of boards are trimmed to size, dovetails marked, sawed and the bulk of the waste removed by your favored technique (I prefer a band saw to the tedious coping saw). Lastly the boards are separated, the baseline marked on the internal faces and the waste pared to the baseline.
On this drawer I choose to use a perky 12 degree tail rather than my customary 10 degree tail. The 12 degree tail makes waste removal in the half blind more difficult and I will likely not use it again.
Note the perfectly sized pin holes, a result of the marking device described earlier. It seemed to get lost in the discussion but the major advantage of this marking devise is that it ensures identical sized pin holes between the tails. Differences in the size of the large tails is not noticeable, but even small variations in the small pin size will be apparent.
A previous critic asked what was to be done with the offensive nail hole. That comment gets to drawer philosophy. It's just a drawer for heavens sake, held together with functional dovetails. Not the place I choose to make a design statement nor a place where I choose to flaunt my skills, not that I have much to flaunt. I just leave the nail hole. When planing the side to fit it largely disapperas, but it could easily be filled.
