Adjustable Pin Marking Gauge Construction
Bill Tindall
The picture sent to me didn't come with how to make it. I encourage those more experienced with working metal to suggest better ways to make the gauge.
Step 1
With a band saw or hand saw saw a kerf half the length of a scrap of wood. Slide a piece of 1 x 1/16" brass into the kerf. If the brass is long enough to make two gauges then enough sticks up from the kerf to use for squaring the brass to the table top(essential!). The screw (black thing in picture) acts as a vise to hold the brass. Saw one side at the angle you prefer for your dovetails.
Step 2
Flip the assembly end for end and saw the other side.
Alternatively, the sawing can be done on a band saw with an angle block and stop for the brass.
Step 4
Saw a keft 15/16" deep on the end of a piece of wood. This kerf MUST be perpendicular to the sides of the block and less deep than the brass is wide. Also it must be off center, see next step.
Step 5
Drill an undersized hole and insert a screw in the hole. The screw will self tap in hard dense wood like maple. Add a nut and a washer to capture the brass part. In my case I cut the screw head off and added a knurled nut.
Final device.
