New WoodChat!
Progress on Chest of Drawers
Bill Tindall
Four drawers down and 3 to go on this "3/4 sized" chest of drawers for granddaughter. In addition to the three drawers I need to make a top(easy), fit the bull nosed facing on the front(not easy) and add a skirt (moderate) and finish(easy).
The drawers are face veneered with some resawed cherry. Some would claim that anything that is veneered on one side needs to be "balanced" by veneering the other side. However, the personnel in a 4th generation cabinet shop said they had never seen the inside of a drawer veneered in Period furniture and my experience would confirm it indeed is unnecessary.
This back view shows better the dovetailed case construction. Dovetailing the back drawer dividers is overkill but I'm not trying to make a living doing this piece, so why not.
All the wedges and putty knives sticking out of drawer 4 are there to center it whilst the glue dries. I let the glue(liquid hide) dry with the drawer in place and centered in opening. No question that it will fit properly with this approach.
This view shows the drawer construction. I am using slips on these drawers. They are unnecessary on the small top drawers but practice here will make installation easier down below on the big drawers. Note the variety of wood. I use up junk in drawer backs and bottoms. Sides are quartered poplar. Runners are maple for durability. Everything on the back has a slight chamfer in case the appearance of the drawer floating about the frame looked curious.
Re: Progress on Chest of Drawers
Stephen Shepherd
Stephen Shepherd
Bill,
Nice work. Let us know how the front drawer veneer works out. I too have heard that it is important to 'balance' the veneer but in 40 years of repairing old stuff, I have only seen two examples that had veneer on the inside of the drawer front. One was a particularly nice English Bureau with a curved front. The core was built up with wooden blocks in a running bond pattern, then cut to the curved shape. Both sides were veneered to hide the brick work construction. After a number of years the core telegraphed through on both sides.
The other was a butler's desk, the top drawer pulled out and folded down to a desk and both sides of the drawer front were veneered.
Then there were the several hundred other examples that were only veneered on the outside.
Stephen
Todd Nebel
Hi Bill,
The chest looks fantastic and your workmanship is top notch. You may have covered this in an earlier post, but the vertical drawer divider is a one sided dovetail joint. Is this a period feature? It looks unbalanced to me.
Thanks,
Todd
a question
Ian (in Sydney, Australia)
Hi Bill
those drawers are looking good
how thick is the resawn cherry on the drawer fronts?
are you planning on using a cock bead to protect it?
regards
They are all half dovetails
Bill Tindall
The face of this cabinet is to be covered with a bull nosed strip. Hence, all the joinery will be hidden.
Half dovetails are easy to fit. I shoot for snug and if the result is too snug then a whisk of the plane makes it just right. An earlier post details the dovetail making process with numerous pictures.
On this piece I averaged 6 minutes per dovetail assembly, not bad for the amount of experience I have. I kept track of this metric because I thought the data might motivate others to use dovetailed assembly if they didn't already. I used to think case assembly with dovetails was 1. beyond my skill level and 2. too tedious. I took a class in the Headley shop in Winchester VA (very highly recommended for learning practical and reliable techniques) where I learned the dovetailing.
It is period authentic. I have seen half dovetails on several pieces in Winterthur and elsewhere. The Headley shop strives for period authenticity in their Shenandoah Valley pieces so I presume this technique was common in this region. In many pieces these joints are hidden, as they will be in this piece, so it may not be obvious how wide spread the practice was.
Re: a question
Bill Tindall
Thickness- it is about 1/8" before finishing. As can be seen the fronts are not planed to a refined state yet.
No cock bead. A bull nosed piece goes on the front edges of the frame. I tested and a cock bead looks just awful with the bull nose profile around it. I did further testing of the durability of the veneered edge. With this thick well glued veneer there is no less robustness of the edge than on a solid drawer. Also, there is no weak grain on the veneer as would be the case with a crotch veneer. In fact I had a drawer clamped in the vice trimming the overhanging veneer. While reaching for something I caught my pants on the overhanging veneer edge and tore my pants. I was sure I must have ripped loose the veneer but it didn't budge. It was a tense moment however.
Re: They are all half dovetails
Todd Nebel
Ok, that makes sense. It's early, I didn't think about a Bullnose detail covering the joint. I've been using stopped dovetail, through dovetail and housed dovetails for drawer rail joints on all my projects for the past several years. I do it for the hairloom factor and try to be period correct. I don't sell anything I make so I have the time.
thanks
