New WoodChat!
2-hour project (too many pics)
Frank D. in Montreal
Hi everyone,
I finally had a couple of free hours for a fun hand tool project. Embarassingly simple, but a good chance to get a little practice in. All I had when I started was this hole in the ground (dug by hand, of course):
and these two pieces of cedar:
I had to join the two pieces cross-wise, so I traced out a lap joint. I was just wondering how many people here look at the reflection of the wood in the saw when they want to saw square to a surface. For those who don't know what this is, if the line in the reflection is continuous and straight with the line of the actual piece, your saw is square. Here's an example of an out-of-square saw:
At the end of a cut, I can even see if it's square without using a square:
A few more practice cuts for waste removal:
Some adjustments to the joint. This is why you want flat chisel backs:
The finished joint (15 minutes...a little slow but I'm a little out of practice):
(My biggest mistake was not getting the edges flush. With the rounded corners I thought it looked better with the 2 pieces offset a little, but this caused a gap later on).
Next I needed a piece to brace the joint. I wanted to use traditional post-and-beam joinery, with no metal fasteners nor glue. I laid out the brace piece without measuring anything...I always measure as little as possible (my sliding sqaure is only for marking and transposing):
Then trace out for the mortises:
Same cuts to prep removal, time is a wastin', go go go with the chisel...
With all the pieces cut, from an offcut I cut out some dowel stock and shaped them with my chisel:
Drilled the holes with my brace, and then rammed the dowels in with my mallet. No need for a fine fit, as long as the dowels are bigger than the holes:
The finished piece. Can't see the gaps from here, looks good. Took me a little less than two hours. My neighbors were getting a little uneasy when they heard me mention "public hanging" to my wife. I've seen some of them use power tools on a regular basis...
The next day...(this is the same guy that made the gilded chest of drawers)
Re: 2-hour project (too many pics)
Scott in Douglassville
That's beautiful.
Pam Niedermayer
Sure is, very beautiful. Tell me, does the two hours count the time to dig/refill the hole? :)
Pam
Nice!
I'm curious about the hacksaw - did you run into some pipe? Or is that how you cut tree roots?
Bought the wood, then I read the fine print, "hole not included." :O
Re: Nice!
Thanks Bill. Yes, the saw is for roots. The steel ber next to it is for banging and wedging out rocks (even had to crack a few big ones that i couldn't move).
Thats GREAT !
No, those are on a different aisle
and the quality of modern factory made holes is so bad, you're better off making your own :D
Beau travail, monsieur!
