Re: Worst of both worlds
TomD
Get a disposable razor and merkur blades. Only because you will probably use it for travel some time, and while learning you will know for sure the razor is not the problem. Then just shave easy parts. For most of my life I have been clean shaven. But when I grew a beard I found the straight razor much easier to shave with more comfortable, and precise. I cut myself less with it, because one never gets that situation with the bad blade. I was doing advance work for our Chairman at one point. And he showed up for a TV media comference with 30 tiny pieces of toilet paper on his face. I bet I know what happened. He decided to use a new blade to get a close shave. Bad idea. The other major comfort thing is that waste hair does not drag with the razor, which is the major problem with modern razors, and major cause of irritation. This is what make the who SR thing so instantly comfortable for me. One thing though, do not allow the razor to go diagonally, a shear cut really wiil cut you. you can press the razor against your skin quite hard, so long as you don't drag it. Of course you can get a better cut with a shear. And being cheap, I do do it. And normally regret it.
You do have to realistically judge how compatible your face is. How rough and lump covered. Some of that stuff might not take to the SR.
Right at the moment I am using this for a disposable, after loosing my usual travel razor. Razor/holder is fine, but the blades are not sharp for long:
http://www.amazon.com/Parker-SRW-Stainless-Razor-120/dp/B002ONHBBW/ref=sr_1_1?ie=UTF8&qid=1316241634&sr=8-1
I could probably get about 5 years out of a pack of these:
http://www.amazon.com/Merkur-Double-Edge-Razor-Blades/dp/B000JPMHWK/ref=sr_1_2?s=hpc&ie=UTF8&qid=1316241746&sr=1-2
I kinda prefer this handle, but the Parker is in some ways better:
http://www.amazon.com/Dovo-Stainless-Shavette-Straight-Replaceable/dp/B000ZXB94I/ref=sr_1_2?s=hpc&ie=UTF8&qid=1316241876&sr=1-2
Then once you have the mechanics down, you can expand into the all steel razors.
