Re: Are there any good books...
Frank D. in Montreal
I don't know that much about furniture, btu mid-century modern is one of my favourite styles. A lot of pieces that I've seen (or have, or have taken apart) seem to have been made by industrial methods. When the materials aren't mixed (metal, stone and wood), the joinery often seems to be dowels. There's a lot of veneer (I heard somewhere that in the 50's and 60's there was a huge influx of teak on the market that was mostly turned into high-quality veneer, which is one reason why everyone was using it back then), and when pieces are solid wood, like chair parts or table legs, the shaping and joinery is often milled with large shapers, as far as I can tell, or pressed with big plywood presses/molds. If I were you, i'd start with a specific design and then just figure out the rest according to the tools you have and the techniques you are familiar with. I think Krenov and Maloof are good indications of how you can make a lot of what you see. If you stick closely to (i.e. copy) the design and construction, you'll be reproducing industrial production, which is often time consuming in a small shop.
My 2 cents
