New WoodChat!
Stanley 46 question
Stanley 46 question
Stanley 46 question
I just accidentally was the high bidder on a Stanley 46 (needs a lot of work), which came, as they often do, with no irons. Two questions:
1. St. James Bay offers a set of irons. Are there other good sources?
2. It appears to me the iron never beds on the moving skate, but only on the main body. It seems that the two functions of the moving skate are to carry the left depth stop (used for dadoing) and the left nicker. Is that right?
Re: Stanley 46 question
Yes and yes
Neal in San Jose
I got my blade set from Jim Reed, but I haven't seen his posts for a while and I can't find him on ebay. Maybe someone will chime in with up-to-date contact info for him.
I don't use my 46 often, but I'm pretty sure you are correct about the functions of the outboard skate.
Great!  Thanks, Derek
Neal in San Jose
Did you notice in #9 that it has been available since Fall 1007? I had no idea he'd been in business over a thousand years.
Seriously, good guy with good products. No affiliation except I have bought from him and wouldn't hesitate to do it again.
Re: Yes and yes
It occurred to me later that it would also, of course, serve as a sole, to discourage the plane from tipping.
Double thanks, Derek!
I knew Jim Reed had been making irons for planes; I didn't realize he'd found an official outlet. He posts fairly regularly on WoodNet, but this saves him time (and me - I can figure out how many pennies to pull together to get the sizes I need).
I like his line, "I also accept MO, checks, cash and anything else you can talk me into." I wonder what the exchange rate is for zucchini, of which we have a surplus at this point in the season?
And I find myself shaking my head about the Interweb again...here are Neal and I, who live two hours apart, getting advice from someone just about directly opposite us on the planet (I did the math once, and directly opposite San Francisco is somewhere in the Indian Ocean, actually), on a supplier 2,000 miles away, who advertises through a seller 3,000 miles away.
Re: Double thanks, Derek!
Todd O. Cronkhite
I think that Jim can easily be persuaded by square Kitty Litter buckets. :D
Hmmmm
I need to start getting my Kitty Litter in those buckets, then.
The real story about the skate
jim reed
The side skate is used for blades larger than 3/8". On most planes it cannot be used with the 3/16 cutter because it will cause binding. It is true that for the larger cutters the skate is used for the nicker. Many of us users look upon the nicker with disdain because there are better ways to get that job done. As said, the real reason for the side skate is to provide a sole runner. The plane has to be held level to the cut to operate correctly. Larger cutters will dig in from the side without help from the skate.
Thanks
I'd kind of come to the conclusion that providing a sole/support was its main function. Good to know that my reasoning wasn't too far off.
