New WoodChat!
ADVERTISE HERE - FREE TRIAL
Case Construction- quick and reliable
Bill Tindall
This picture shows the goal, a snug fitting dovetailed drawer blade. (This case front will be faced so I was unconcerned about avoiding the nicks below the dovetail.)
I have built dozens of case pieces and seldom have I made two that were made the same. Over time my skills have improved and the philosophy evolved. But I think I have finally settled on what for me is the quickest and most reliable means of assembling a case piece- defined as a box with sides, top, bottom, drawers and perhaps doors.
Preparing the drawer blades: Step 1 is to make the drawer blades. The handy router jig I made makes short work of preparing the dovetail on the end of the blade. The blade is inserted flush with the top of the jig and mowed off with the dovetail bit. By moving the router fence the thickness of the dovetail can be varied. Critical: the narrow waist of this dovetail must be just slightly wider than the width of a dado that will be plowed later. So, if your dado plane or router bit is 3/4", the narrow waist of the dovetail on the blade is made approximately 1/64" larger. You will see why soon.
Layout - Layout of the drawers is done with two dividers. One is set to the width of the top drawer and the second to the thickness of the drawer blade/divider. First, the two sides are clamped together oriented as they will be in the finished piece and the back edge of the sides up. Starting with the small divider mark the location of the top blade by making a prick with the divider on the top edge of the clamped sides. (For a case with more than one drawer in the top row it is quicker to dovetail in a false top rather than a blade and all the additional framing it would entail. ) With the second divider measure off the height off the top drawer and locate it with a prick on the edge.
It is common in fine pieces that each drawer is larger than the one above it by the width of a blade. This approach now makes it easy to see how the layout can be done with just the two divider settings. The third drawer down , for example is measured by one large divider distance plus two drawer blade distances. When finished marching off these spacings with the dividers scribe across the the edge.
Cutting the dadoes Next fold the sides down in a book matching orientation and clamp the two sides together. The inside of the case will be facing up and the marked edges on the outside of the fold. Clamp a straight edge across the assembly, aligning it with the scribe marks made on the edges and plow a groove with a plow plane or router. Important: The width of this dado should be ever so slightly smaller than the waist of the drawer blade dovetail.
Making the dovetail : Next saw to the depth of the dovetail on each side of the dado. I used to use a guide block for this operation but I have weaned myself of this crutch.
Now chisel out the dado to the depth and width of the drawer blade dovetail.
Finally, using a gauge block and wide chisel cut the angled part of the dovetail.
And you are done
If there is fitting to be done it is a simple matter to plane a whisker off the flat side of the drawer blade. Once I have done one or two I get calibrated and I rarely have to adjust a blade.
This technique is fast. On average it took me 6 minutes to complete each dovetail. A dovetailed case is self squaring, self clamping and no construction is stronger, more ridgid or resistant to the sides bowing over time.
Re: Case Construction- quick and reliable
PS
Bill Tindall
These pictures are off a 3/4 sized cherry chest of drawers I have underway for a young grand daughter.
more comments on the dado
Bill Tindall
I have seen a shallow dado across the interior of old case pieces and always wondered why it was there. It certainly was not needed to add strength to the drawer runners(here defined as the things running parallel to the case side). I think in fact it is a handy marking and alignment device.
1. If the drawer spacing is precisely marked on the back edge of each case side and this dado plowed against a fence bridging these marks, all parts of the drawer support will be in one plane. Ensuring the four supports are in one plane is difficult by other means and if one part is off the drawer is difficult to fit. Even if this dado is plowed with a hand plane it is quick to do. The problem with plowing it with a hand plane is that dado planes are boggling expensive and difficult to find in sizes ideal for this operation (5/8"). Eagle sells pattern bits in 1/16" increments so a pattern bit can be readily found for what ever size dovetail waist is made. For this 3/4 sized chest I am using 3/4" stock instead of my customary 7/8, so for this case a 9/16 pattern bit was required.
2. This dado also provides the start for the drawer blade dovetails. Making the dovetails is a simple matter of then just deepening the dado and paring the angled part. The dado sides provide guide for the saw in case your sawing is wobbly, like mine.
3. The dado also makes installation of the runners easy. Alignment with the blades is assured. For a modest drawer the runner can be simply nailed in place. Alternatively it can be screwed or half lapped some onto the blades.
Re: more comments on the dado
TomD
My dad used to run a university, and the wood shop used dovetail/dado assembly to make student desks etc... The drawer fronts were also attatched that way. Seems to be a fail though where delicacy is concerned, or where actual boxes are needed that do not have kicks or other offsets.
Warren in Lancaster, PA
I don't think I have ever done a system that is so much work as what you present. Here is a popular 18th century system I sometimes use.
Make a 1/8 dado in the case that is the same width as the blade and the runner are thick (perhaps 7/8). The blade fits into this shallow dado and in addition has a dovetail (not a half tail) on each end. Saw the dovetails on the blades then mark the dovetails on the carcass from the blades. Next saw the carcass right on the dovetail line, not straight down, then chisel the waste.
This system saves time because 1) there are no dovetails at the back of the case; I have never seen such on old work. 2) the dado is full width so you do not need to make rabbets on the runners. 3) the dovetail in the case is sawn right on the line, making less chisel work and no need for a guide block.
I agree with one point
Bill Tindall
I have never seen dovetails on the back of a period case either. But mine are so quick and easy to make that I put them there anyway. And it took an hour to do so. By dovetailing the back instead of the traditional approach I may have frittered away 30 min I didn't need to, but it was cool in the shop, and hot as blazes outside. Granddaughter, the chest's future owner, help chisel out some of the waste.
A professional period furniture maker, while examining the recent bow front with its dovetailed behind muttered softly "it ought to be strong enough". (Same person that showed me the guide block technique for doing the half dovetailed drawer blades) Just in case someone should ever ask I timed that it takes me an average of 20 seconds to chisel out the waste with the guide block- almost as fast as sawing it. With granddaughter helping it is somewhat longer, a lot longer.
I suspect that most people avoid dovetailing a case together because it appears to be difficult and time consuming. A picture of the joint you describe, as seen in some books, would certainly dissuade some. If they do dovetail the case they likely use a router to cut the joints. It is extraordinarily difficult and time consuming to precisely fit the joint with router production of both parts. And it is easy to screw up too, either the location of the cut or its size(I have personal experience). The approach I have described is quick and reliable and it doesn't take much skill or practice to execute. For people building stuff part time not having to rely on any ruler measurements may be especially attractive.
