New WoodChat!
Made cabinet scraper burnisher; small problem
Nathan
I made a cabinet scraper burnisher. The handle is carved from a branch (air-dried apple). The copper ring is sawn from a length of copper water pipe. The business end of the burnisher is an HSS rod (metal lathe tool blank).
Everything went fine until I got to the final step - ramming the HSS rod into the handle. First I ground a small taper on the end. Then I bored the hole in the handle. The rod is 10mm, so I made the hole 9mm. (This was a mistake - should have been 9.5 mm.) At first the rod didn't want to go in the hole. So I ground the rod down, making a very slight taper on it.
This being the first time I've ever made a tool, I was in an over-excited state, hurrying. I was going back and forth from grinding the taper to tapping it in with (small) sledgehammer. Once it started to go in, I started tapping more insistently, hoping that it would go in all the way. It didn't. :(
After awhile, I was banging pretty hard and making no progress. So I'm left with the tool in this state:
The tool is seated in the handle very well, but the "plan" called for it to go in deeper. The ground portion sticking out is 1", so ideally I'd like to ram it in another 1", but I'd settle for 3/4" or even 1/2".
So far, I have two ideas - first, I could put the tool in a lathe or drill press to get it spinning and then sand and polish the unsightly portion to make it less unsightly. Second, I could try to pull the tool out of the handle (but how?) or at least rotate it to loosen it up. But I don't know how I could do that without damaging the handle or the tool.
The first idea seems more realistic than the second. What do you think?
Re: Made cabinet scraper burnisher; small problem
When you start over......
Bill Tindall
1. Use a carbide tool blank or 1/4" Formica trim bit inserted end for end to leave the unground part sticking out.
2. If the rod is 1/4", drill a 1/4" hole in the wood, for example. Wood always under drills a hole size.
3. You hardly need the metal band.
Summary....Make a new handle, eliminating the metal band. Put some swell in the handle so it fits the hand better. Drill a 10mm hole. Insert rod as far as needed with gentle taps.
Re: Two suggestions
North of the Border
1) Second, I could try to pull the tool out of the handle (but how?) or at least rotate it to loosen it up.
Try using a vise grip/locking pliers to hold the rod(at the flattened area) and turn the pliers while holding the wooden handle freehand or with a handscrew ( cut one or two v-notches on the jaws).
2) Can you epoxy a short piece of copper tube similar to the hoop in color or material to cover the flattened spot?
Re: Two suggestions
"Can you epoxy a short piece of copper tube similar to the hoop in color or material to cover the flattened spot? "
Except then he's got a two-diameter handle, with the working surface out beyond the smaller diameter part of the handle. Seems like it'd be awkward.
Robin Corell in Atascadero, CA
When puting a handle on a tanged tool I always climb the tool in to the handle rather than taping the tool into the hande or driving the handle onto the tool. To climb a tool into a handle push the tool into the handle as far as possible by hand then while holding the the hande with the tool in mid air strike the butt end of the handle with a mallet. Contrary to what you might expect, the tool will climb into the handle. This method also works for seating hammer heads on handles and it allows delicate carving tools to be handles without taking a chance of chiping the edge.
When you describe a taper I am assumeing a square taper rrather than what would look like a spike. With a square taper I drill a stepped hole. I drill the full depth with a bit that is about the same diameter as the side of the square tang at the small end. I then use a larger drill bit to enlarge the hole about 2/3 the depth to a coresponding size on the tang and repeat 2 or 3 more times. I rarely ever have any problems using this method and have yet to have a handle come off when I have used this method.
Robin
Moses Yoder
Moses Yoder
I notice taht Lee Valley's super hard scrapers are RC 48-52 hardness. I wonder how hard your scrapers are, and how hard your burnisher is?
