Coming soon-diamond plane blade
Bill Tindall
We recently had an A2 plane iron coated with a diamond coating. The advantage of this coating is that it is done at low temperature and the steel won't soften during coating as is the case with the conventional TiN process. Also in this case a bevel up plane will be used for evaluation, a case where the coating is expected to be more effective than coating a bevel down plane configuration. Wear evaluations will be done by our WoodCentral expert in these matters, Steve Elliot. Stay tuned for more results on this blade as well as new pictures of the TiN blade.
