We value your privacy.
I am so annoyed I could bite, well, screws! I own a dozen or more screw drivers and none fit a #4 slotted screw. Actually, none of them ideally fit any slotted wood screw. And, the way they are sold one has no clue what they might fit if one is ordered. To wit, a 3/16" screw driver!?! What size screw does a 3/16 driver fit! Now if one needs to fit a #2 Phillips one can buy a #2 driver, ditto for square drives. But need a driver for a #4 slotted.......you're screwed. To further the problem they are all tapered in at least one plane and likely two. Wood screws have straight sided slots, so why are the drivers tapered in width and thickness?
With tools being offered for every imaginable purpose it would seem that someone must sell a slotted wood-screw driver. Why everyone doesn't is a mystery. I' m trying to imagine how I might make one from drill rod, or maybe a drill. Oh, an M2 screw driver, I like that.
Re: Does anyone sell a driver for slotted wood screws
I'd just get a chunk of O1 drill rod and grind a bit to fit your needs. Chuck it in your brace and screw away! I did that to make a turnscrew for my plane cap irons. Made it from a chunk of tire iron.
The slotted driver inserts that go in 1/4" hex drives are often ground with a strong curve from the hex that comes out straight at the slot - like the old English turnscrews. These still don't specify the screw size, but if you get a variety, you should be OK; and the inserts are cheap, 99 cents or so. It's fairly easy to find a screwdriver handle that takes these inserts, but do spend enough money to get a good one. I've had some on which the handle slipped on the shaft when I applied torque. Find your nearest contractor's lumberyard - the hex bits at my local yard are much higher quality than the bits at the big boxy stores. Because they're designed for power driving of hardened screws, they're tough little things, too - in a manually powered screwdriver, you could probably go years without having to replace them.
I was told once that American screwdrivers are designed for machine screws, not wood screws, and that proper turnscrews are superior for wood screws. I suspect that the size name conventions for slotted screws probably stem from the fact that slotted screws predate standardization by quite a few years, while other screw head types - Phillips, Torx, etc. - were developed concurrently with the idea of standardization, so it was not a great leap to mandate a limited number of sizes.
The good news, I guess, is that it's far easier to grind a screwdriver for a slotted screw to fit the screws you're driving, than it would be to resize a Torx driver for an offbeat size.
I've noticed also, to my frustration, that the dimensions of slots in slotted screws are so far from standardized for a given screw size as to induce hair-tearing fits. Some of the slots on machinist's tools (like the screws that hold the hooks on hook rules) and the slots on saw nuts are particularly maddening - the slot is so narrow for the width of the screwhead that it's very hard to grind a proper screwdriver that will turn the screw without breaking. I've taken to finding the right thickness of feeler gauge and turning it with pliers right down next to the slot; that usually works...but I digress from your question.
Indeed, I have tended to place greater importance on the plan shape of the flat head rather than its width. Triangulated ends are more likely to cam out of a slot than ends that are parallel (or close to it), even if they do not fill the entire width of the slot.
I have ground the ends of driver heads to my preferred shape. Hollow ground, that is ...
Typical driver end ...
Hollow ground set ...
Make your own drivers. This one is a converted turnscrew for Stanley levercap screws ...
Is the grinding done free hand? It would seem a daunting task to free hand grind the flats both parallel and just a few thou. less than the screw slot. I do have plenty of useless screwdrivers to practice on.
I'll second the gently, although "gently" is a little easier on my hand cranked grinder.
Parallel is quite easy to eyeball - if you done a tiny "touch" grind on the end it's nice and shiny, so as the sides come close together, and the end is getting thin, out of parallel is really easy to spot, and can be corrected by gentle pressure (more "emphasis" than pressure, really) on the wider side.
Thickness is easy - make sure when you start that the driver WON'T enter the screw, and stop grinding when it will.
Did I mention "gently" ?
BugBear
Brownells has a special mounted stone that can be used to grind the screw driver tip. I can't access the site to post a link to the tool at work (draconian web filter) but I can post later to the thread if necessary. It duplicates the "gunsmith" style parallel grind. It can be used in a drill motor or drill press with a little bit of jigging to position the workpiece. Intended to allow custom fit by modding the insert bits for specific screws it can be used to make any size tip desired.
Joe
I have some drill rod ordered. A knife maker whom I give tomatoes to owes me one , so the heat treating is taken care of. In 3' of drill rod surely I can get one tip right....did someone say gently?
But, why doesn't Lee Valley sell a suitable screw driver for slotted screws? I found I could buy one from the gun smith supply for a kings ransom. And what ever purpose is served by the typical keystone blade shape in my useless for slotted screws dirivers? I feel cheated. I finally find a source of quality brass screws (Whitechapel) and I don't have a driver.
If you have old back issues of FWW, there is an article somewhere that describes "hollow-ground" screwdriver tips. That's what I did with my Footprint tips. They're much less likely to cam out.
