We value your privacy.
A friend of mine is selling his chop saw and wants to buy a miter box and saw [I would like to think from my influence] and needs to know which is the best one for him to buy.
I just use a miter block and small unbacked saw for my miters but he wants something that is adjustable.
I think the Stanley 358 is a good one. You will be a little hard pressed to find them under $100 but might get lucky on ebay because of the cost of shipping. Mine of course was $20. You can see pictures of one at the link below.
"I just use a miter block and small unbacked saw for my miters"
I would like some means of reliably sawing miters on small pieces, molding and the like, 1/2" or so thick. I have searched for a tiny miter box, and even made one that didn't work very well. Please describe in more detail this means you have of cutting miters and how it could be used to cut a miter on a small molding.
Millers-Falls, Stanley, and others made miter boxes that used two posts to guide a backsaw. The exact approach, of course, varied: the Stanley saws like the 358 that Moses pictures use castings that carry the saw, running on vertical posts; the Millers-Falls Langdon Acme box (I own one, but don't have any pictures) uses split rods that run up and down in hollow posts.
I acquired mine at a yard sale, $15. The big problem, from what I've heard, with buying from eBay and places like that is the shipping: these are bulky, heavy devices. It's also true that pictures won't accurately show some of the critical condition issues: is the saw straight, is the box warped, etc. So buying a saw and box that you can touch and inspect is important, I think, unless you can find a seller knowledgeable enough about these things and trustworthy enough to act in your behalf.
In my limited experience, lesser miter boxes aren't worth it. I owned a Stanley 150 box for a while, for instance (link is to an eBay auction that will probably go stale after a while; but Googling "Stanley 150 miter box" gives plenty of pictures), and found it not much use for anything larger than picture frame molding, and marginal even for that. With the M-F Langdon Acme box, I can shave a sawkerf's thickness of wood off the end of a miter, because the saw is held so firmly.
As to finding one: they're not common devices (in the heyday of these saws, they were priced equivalent to a modern Unisaw table saw; not likely to be something homeowners would have). Some diligent searching will be required.
There are modern versions of these saws. I don't know much about them, but maybe others with experience with them can weigh in.
but I can talk about my limited experience with miter blocks. Miter blocks are basically a thick and moderately wide piece of stock with a rabbet on one edge wide and deep enough to accept the molding to be cut. You cut your desired angles into the remaining width of the stock, and the resulting sawkerfs then guide your saw in cutting accurate angles. Obviously, careful layout and cutting of the initial sawkerfs into the block is critical. The image below (not of my miter block, see next paragraph) is far more useful than my description here.
I made one, some years back, from a piece of pine offcut from some architectural millwork (door jamb? something like that). I used a hacksaw as my saw - at the time, I didn't have a good backsaw - and it turned out to be a good idea, allowing for very clean, precise cuts. With this, I was able to cut dead accurate miters on 1/4" by 1/4" stock, with no cleanup of the cuts needed. I wish I still had that block - unfortunately, the pine used for millwork in this area is rather sensitive to mold, and it got wet at some point and deteriorated.
I have the Stanley 150 miter box also. I used it once to cut PVC pipe to length in the crawl space underneath our house. It was the only time I ever used it. $90 is way overpriced.
I just carefully marked it out then made the cuts with the same saw I will be using. A bit tight at first but loosens up after a time or two. I don't own a table saw.
"Carefully" is an important word there. I have, on occasion, used a block of wood with a true 90 degree angle on it to ensure that the saw was cutting vertically; but I've found clean, clear layout lines coupled with "sawing on two lines" - alternating the cut on the vertical and horizontal lines until there's enough of a groove for the saw to track in - just as reliable.
What Stephen doesn't mention about using the same saw to make the cuts that you'll use for the actual work is that, since the cuts in the miter block/box are what guide the saw, you want them to hug the saw as closely as possible. For that reason, the use of a tablesaw would NOT be good - you'd wind up with a groove that's so wide, you'd have to attempt to hold the saw against one face or the other of the cuts at all times, a nearly impossible task.
Which, incidentally, is one failing of commercially made miter boxes, which come with over-wide grooves.
'Teh Schwartz' did a thing on Millers falls cast iron miter boxes a while back, and drove up the prices on eBay. He then pointed out on his blog that yard sales and flea markets are the way to go, because eBay trends move fast... mainly, I think, because eBay's easy.
One of the greatest ideas I've seen in shop-made miter boxes was a wooden model that was chopped at 45 degrees at the end, providing a sort-of built-in shooting board. And that's the kind of adjustability I can work with.
Why?
The last time I really got regular use out of a shooting board, and had to do angles, it was for an oval medallion inlay: bunch of triangles of sand-shaded maple inlay. I had no interest in making shooting boards for every angle, so I made triangles out of plywood to make up the difference.
Take a miter block, draw in the 5 degree angles. And add a 90 degree shooting board in on the end. If there are regular angles he wants to cut, hold the wood at the angle on the miter block, and clean it up on the shooting board end, with a wooden triangle. If it's off, shim with a bit of tape.
