New WoodChat!
drawer divider layout question
Bill Tindall
The task is to locate the drawer dividers/blades on each side panel of a chest of drawers. The divider mortise and tenon or sliding dovetail is located front and back and on each side of the case and ideally each set of dividers, front and back are exactly the same spacing. No matter what technique I use to mark these locations I wind up with small but annoying errors that leave the spacing between dividers slightly different side to side, or front to back. Then the drawer must be fit to accommodate the error.
What do you all do to mark divider locations in a case piece? On this chest I will be using sliding half dovetails for the dividers and solid dovetailed top .
Re: drawer divider layout question
How do you make the sliding dovetails?
Pam Niedermayer - Austin, TX
Paul Dzioba
Mark a 'story' stick with your drawer blade spacing. Butt and clamp your side panels front edge to front edge. Use your story stick to transfer the layout to the back edges of both side panels. You now may connect the marks with a straight edge. I usually tack a batten across the marks and use a dado to plow a shallow dado. You may use a electric router instead. With the fronts butted together, all the breakout from the dadoing is at the back unseen. Proceed to cut the dovetails in the front and the rabbetts for the back. For this to work your panels must be square and the same length.
what detail?
Bill Tindall
I cut the tail on the divider end first with a clever jig I made, then cut the socket to fit the tail. I cut the socket with a combination of saw, chisel and router plane as learned in the Headley shop, paring it with the chisel, or strokes of the plane off the half tail, to get a good fit. I can describe either in more detail of you are interested. It all goes quickly even for my predisposition for getting on with it.
Since being shown the half tail for this joint life has been grand. It is so easy to fit.
that was interesting
Bill Tindall
But, I am satisfied with the way I cut the joint. It is fast and doesn't involve so many tools that I don't own. It is my lay out strategy that could stand improvement.
thanks....
Bill Tindall
Looks to be a reliable and easy way to accomplish the task. I wish I had a dado/plough plane for this joint. It seems to be the last classic plane that nobody has made in a modern version. Electric routers involve a fence positioned at yet another line, with yet another opportunity for small errors to creep in.
what error?
Ian (in Sydney, Australia)
to my mind an "error" in this context would be a noticable difference in the width of two side by side drawers or where the vertical dividers for a bank of drawers are missaligned.
you post suggests that neither of these is your problem
traditionally the drawer front is fitted after the case is assembled, so small differences in the width of the opening (across the front) are accomodated by small changes to the width of the front
differences in width betyween teh front and back of the opening are accomodated by deliberately making a tapered drawer -- the drawer back would normally be cut 1/32, or so, narrower than the front.
Dean J from MN
I'll 'second' Paul's method, it is how I layout and cut the dados for drawer blades as well.
Re: what error?
Bill Tindall
The annoyance is that it can happen that the space for the drawer height is slightly different side to side or front to back. Yes, I agree that these small differences can, and will, be accommodated in drawer fitting, but it occurred to me that of the many possible ways to lay out the drawer dividers/blades some one has probably figured out the quickest and most reliable way. For some reason I never thought to ask this question when I was in a shop that did this kind of layout.
I have seen a lot of complicated ways to do the layout. One thing I have learned is that the cabinet makers of an earlier time had quick reliable methods that usually didn't involve highly accurate rulers, precise measuring, etc. a modern cabinet maker might be predisposed to rely on. For example, for this case piece I rediscovered the ease with which the drawer spacing could be done with dividers, precise to the resolution of a pin prick.
So much to learn........
Re: what detail?
I think that there's a difficulty in cutting sliding dovetails that makes them inherently imprecise, and that it's very easy to saw in a different place with each one such that the total of them all is off a bit, but noticeable. So I'd say saw to the line the same way on every slider and minimize the use of chisels.
Pam
then use a "story stick" as suggested by Paul
