New WoodChat!
A55 Smoothing Plane
Upgrading an OWT.
Upgrading an OWT.
Upgrading an OWT.
When Lee Valley recently offered a range of narrower irons for the Large Router Plane, I bought them .. and then had a brainstorm.
Some while back I built an OWT (Old Woman's Tooth), a wooden router plane. I made an iron for this out of a hex key. This worked pretty well.
The article/pictorial is here: http://www.inthewoodshop.com/ShopMadeTools/OldWoman%27sTooth.html
This is a small router plane, just 6 1/2" along its length and 3"deep. This places it about in the middle of the small and large LV router planes.
The OWT was intended for narrow blades, and I had planned to make more in the 1/16" - 1/8" range for use with inlay. However with the release of the new LV blades I decided to modify the OWT to use them instead.
The modification is quite simple. Drill a hole, and drop in and epoxy a small section of aluminium angle to support the angled profile of the LV blade.
I have a screw pushing the blade against the aluminium section, but one could also use a wedge.
Wait ... there is more!
LV also recently replaced the depth stop on the Large Router Plane. This was something I had nagged them to do - I found the early split ring system fiddly and preferred the clamp on the LN version. Along the way I built my own depth stop, which is the version I showed LV.
http://www.inthewoodshop.com/ShopMadeTools/DepthStopsForVeritasRouterPlanes.html
LV came up with a better solution than mine, which I field tested for them. Excellent solution.
The replacement on the LV now freed up my shopmade version, and so I decided to add this to the OWT ...
So there you are - if interested in building an OWT, consider using the LV or Stanley blades (which have the same profile).
Re: Upgrading an OWT.
The aluminum angle's a clever solution. Most commonly available angle in the U.S. is like the piece shown in your picture, with sharp inside corners - but I've got a couple of pieces with radiused inside corners, such as you encounter with steel angle stock. Anyone planning to adopt your idea should be sure to use the unradiused angle, I imagine.
Not necessarily, Bill. The corners on the LV blades are all relieved. I guess it will depend on the radius of the inside curve of the aluminium sections to which you refer.
steve mackay
THAT is a stunning tool !
