New WoodChat!
Clad Wood
Clad Wood
Stephen Shepherd
Clad Wood
Stephen Shepherd
I am going to make some pine numerals to replace the lame numbers on my home address. This will be an exterior application, I will linseed oil the wood and allow it to dry.
I intend to clad them with some copper foil 0.002" thick. My question is: will it be alright to nail the copper foil on with brass tacks? Or will there be a reaction? My copper tacks are huge and too large for this project.
Stephen
Re: Clad Wood
Re: Clad Wood
Brass contains copper, and you're some distance from the nearest ocean (although I don't know how far you are from the Great Salt Lake). I would think it would work, unless you plan to immerse your house in battery acid, and probably even then.
Bill, no metallurgist
I wouldn't, myself, use pine in an exterior application, though. I still have vivid memories of removing the pine siding on our front porch (when we rebuilt it) by grabbing hunks of what felt like wet Kleenex and dropping them in the wheelbarrow. Most pines, I believe, have very little exterior durability. Any of the cedars would serve you better. Redwood's hard to carve.
Re: Clad Wood
Re: Clad Wood
Bill Tindall
brass is good. Finding copper would be better. In a wet environment the zinc from the brass will leach in time. Iron will corrode quickly, but maybe not in a dry climate.
Re: Clad Wood
Re: Clad Wood
Larry Williams
I know you're real fond of linseed oil--so are mold and fungi. Every time you get a temperature swing that causes condensation or dew, you'll be feeding wood eating stuff in the nice incubator you've made under your cladding. Skip the linseed oil.
Re: Clad Wood
Use white oak or mahogany...
patrick gibbons
and don't worry about the rain.
Re: Clad Wood
For something totally different...
I wonder if you're making this too complicated, Stephen? If you're cladding the numerals, why don't you cast them out of plaster or bondo or something and stick the copper foil on with some kind of sizing. (I'll bet you have just such a recipe in your recipe book.)
Regardless, .002 foil is mighty thin to be nailing with anything. Why don't you wrap the copper all the way around the numbers and secure it there with epoxy or whatever nineteenth-century glue would be appropriate, then just nail through the whole number to stick it to the house or whatever. A couple copper nails should do the trick.
Re: Clad Wood
Re: I agree bondo ...
George in mosquito filled Lowell, Mich.
sealed with poly and then epoxy + copper or even ........Gold Leaf!!!!!!
Work safe,
George
