New WoodChat!
Designing and Building an Entertainment Centre
I was in two minds whether to post this. It feels early in the build. It may take some time yet. On the other hand it has taken too long already and this may force me to get a move on!
I've called it The Start ...
http://www.inthewoodshop.com/Furniture/DesigningandBuildinganEntertainmentCentre.html
It would be great if you posted your own builds, or even just offer ideas. It is never too late to incorporate something new. At the least someone will gain something from you.
Re: Designing and Building an Entertainment Centre
Feet
Bill Tindall
The feet are too simple/plain. I am not a good enough designer to suggest how to dress up but they need a bit of something. Maybe post on main message board. there are some awesome design people over there.
Mark Salomon
Well, the clean and modern approach suggest that the design you've included for the base/feet are fine. However, I agree with Bill that the base is going to look odd if you incorporate brass edging and pulls as you state. If that is the case you might want to consider the addition of bun feet instead to keep it tied to the old look of military cabinetry.
Re: Feet
Pam Niedermayer - Austin, TX
Are you talking about the ovoid feet on the campaign chests? I don't see any feet yet on the carcasses Derek has dry fitted. And, I don't see any need for visible feet on the carcasses, looks great sans feet.
Pam
Re: Feet
Oh, on the drawing. Duh! I agree that the feet as drawn don't look right. Probably Mark is right.
Pam
Jesper, Denmark
Jesper, Denmark
Hi Derek,
One of the difficulties with entertainment centers is how to run the multitude of wires and cables connecting the various componets - and hiding them.
I have built a preliminary mock-up of an entertainment center and have incorporated a recess behind the base for the wires. The center is located against a wall, where the power and aerial connections are in the baseboard. The base is with a solid front, not feet, so the wires are not visible.
Also, with modern flat screens, you probably want to add speakers to improve the sound, so you need to consider which type of speakers, and whether they should be incorporated into the center. My major error was to build the mock-up before buying the speakers (Sony sound bar and subwoofer), so now it needs to be modified to place the speakers in the center and hide their connecting wires.
Unless you've got magic speakers that don't vibrate and magic components that don't vibrate to death, it's not a good idea to put them in the same cage as other electronics.
Pam
Hi Jesper
Thanks for the comments.
When it comes to the audio side, it gets really simple - I do not have a surround system. I may add this component later, but I remain wedded to my neanderthal stereo system as I actually listen to music when I can. The system includes large floorstanding B & W speakers that I would not trade for anything. The TV can play through them - via an amplifier - as well (which it often does as the sound from the TV is diabolical). I have yet to hear a surround sound system that I like (without spending a fortune). My only concession to modern times is that I have moved the vinyl system to another room, and this one is based around CDs (iPods are not for serious listening). Storage in the cabinet is for a DVD recorder, amplifier, and CD player. Now if I decide to add rear speakers, I shall change the amplifier, but the side/main speakers will remain. This one of the reasons for the length of the twin cabinets - there is a maximum distance that the main speakers can be set apart before the stereo imaging is affected.
I did not include all this in my write up simply because I thought it too nerdish. However it is a pertinent issue when designing an entertainment centre. I guess we all have different ideas and priorities. I am really interested to hear of yours and others.
Hi Mark and Bill
Thanks.
Your combined comments have made me reconsider the brass on the corners. I now think that will be out of keeping on a "modern" version of a military-inspired cabinet. I still like the idea of traditional (military) brass inset pulls for the drawers. I still like the low oak base (in place of round feet) as this creates a single piece of furniture, while adding an interesting contrast. Open to thoughts here.
Phil
Here's my interpretation of the classic Shaker HD big screen TV cabinet (10 feet wide x 4 1/2 feet high): a place for everything and everything in its place (mostly)
Hi Phil
That's Big! And beautiful. I'd like to see pictures from the door side.
What will you do when you need a new screen?
Did you do anything special for ventilating the electrical equipment?
Phil
Derek:
I will try to upload some more pics of the right side when I get a chance.
By definition, I will never need to replace that set: but if by chance it should need replacement, no problem. First off, the aspect ratio of any replacement set should be the same, so for a similar screen size, I would expect it would be a fairly close match. Any gaps could be filled in by additional trim set back from the front face frame. By the way, the top is removable: I've used dowels to position it on the base, but it lifts right off (there was no way I'd be able to get that snug a fit if the top were permanent). What's nice about this design is the least attractive portion of the set is hidden.
As far as ventilation, the back of the lower section where all the game consoles and components are is completely open: makes wiring easier and gives the heat somewhere to go. The top section has a back panel about one-third down from the top for rigidity, but I've never had a temp. issue with this configuration.
Right side houses game discs and cartridges, controls, cables in the bottom, and books/magazines on the top. No matter how much storage space I build, its seems to get filled up?
Regards,
Phil
