New WoodChat!
Quirky Craftsman brace
I picked this up at a garage sale today - I'd have left it there, except it came as part of a package with some bits I've been watching for (the elusive 3/16" auger bit and a doweling auger bit).
It's a fairly routine better-than-average brace (ball-bearing head, for instance; but a nothing-special chuck), but I've never seen a crank handle like this one. It's non-ferrous - probably an aluminum alloy - that looks to have been cast in two parts, held together by pressed-on collars on both ends. Not sure that I'll keep it; the handle squeaks in use, and it's not like I need more braces.
Re: Quirky Craftsman brace
Stephen Shepherd
Stephen Shepherd
Bill,
Is the 3/16" an Irwin or Jennings Pattern?
Stephen
Bits
The 3/16" is an Irwin (solid center) pattern. I'm having trouble reading the maker name - not a lot of room to put it on the shaft. The bits are a mix of makes - Millers Falls, Irwin, and a company called "Snell Mfg." - all U.S. made.
No visible maker on the doweling bit; the shaft down by the square taper is kind of beaten up.
Re: Bits
Richard in Oakville Ontario
I have a Russell Jennings 3/16" doweling bit. No surprise, it is the russell jennings pattern. The spur lips are a little messed up but it still works.
