New WoodChat!
T rabate plane
T rabate plane
Stephen Shepherd
T rabate plane
Stephen Shepherd
I picked this up today at the local swap meet. The fellow was asking $15.00 for the plane, I didn't pay that but did talk him down. A friend standing by said he thought the blade was all used up, that helped get the price down.
Photobucket
It is bedded at 53 degrees and has a mark on the blade but until I clean it I can't make it out, but there is a number stamped on the iron part of the blade on the back at the bottom; either 142 or 42. The blade is just over 1 1/2" wide, is laid steel and the beech plane is 11 7/8" long. The blade stood up well to sharpening. The wedge is made of ash.
t rabbit 2
Meant to be used on its side there are no chamfers on the top corners but there is a scoop out on the top that makes it easier to grip.
Any ideas as to the country of origin?
Stephen
Re: T rabate plane
Re: T rabate plane
Larry Williams
It's Continental. The wedge is a replacement and the shaped wrong for the style.
Re: T rabate plane
Re: T rabate plane
Wolfgang Jordan
Such a scoop is a common feature on Dutch planes. Here are two examples of Dutch T-rabbet planes in the collection of the "Fries Scheepvaartmuseum" (http://www.friesscheepvaartmuseum.nl/):
http://www.friesscheepvaartmuseum.nl/fsm:col1:dat3045
http://www.friesscheepvaartmuseum.nl/fsm:col1:dat13929
I agree with Larry about the wedge. Dutch wedges have an angular shape, like in the examples above.
Are you sure about beech, the body looks like hornbeam to me?
Wolfgang
Re: T rabate plane
Re: T rabate plane
wilbur
There's a Japanese version of this plane, called a gotoku plane.
"Gotoku" translates as "five purposes", meaning that you could use this plane in five ways: as a smoothing plane, making a left rabbet, making a right rabbet, trimming the left wall of a groove (turn the plane on its side), and trimming the right wall of a groove. The dimensions of the left/right projection were sized to fit a standard groove that was used in Japanese woodworking, sort of their equivalent of a 1/4" x 1/4" groove that everyone uses for drawer bottoms.
