New WoodChat!
Plastic question....
Edward in Vancouver
Although this is a handtool, and one I use almost every day, and even one I made myself from beech scraps, pizza wheels, all-thread rod, and acorn nuts, but I don't know if this falls under the "Hand tool" category.
In any case I use this tool to cut soft chocolate (ganache)centers into squares before I enrobe (dip, or cover) them in liquid chocolate. If the tool is warmed slightly in the oven it will cut nicely. And I use it to score sheets of caramel and nougat, so I have guidelines to follow with when cutting with a heavy Chef's knife.
However it is obvious that the wood is cracking, and in a pastry shop hygiene is important. I usually rinse it off and toss it in a hot oven for a few minutes to sanitize it.
I need to rebuild it, and I need a material that can withstand the temps of an oven for a maximum of 10 mins @350 F, or in a commercial dishwasher (a commercial d/washer only has a wash cycle of about 2 mins)
Aluminum or brass would seem like obvious choices, and ones I could easily work with or turn on my lathe. But both metals oxidize, turning my hands all nice and black, and they do get "toasty" when placed in a hot oven.
So, wood is out, metals are out, plastic would seem ideal. But what kind? I don't know a lot about plastics.
Suggestions anyone?
Re: Plastic question....
Well 10 min @ 350deg...
Scott Burr in Ben Lomond CA
Any (most any) plastic can handle that. I'd look at a food grade HDPE. Like most cutting boards are made from. Very easy to turn and it planes wonderfully :b
A recommendation
Bill Tindall
Nylon has a melting point over 200 degrees C (around 250 if I recall correctly). Ditto for polyester. Polycarbonate is even higher. However, nylon machines delightfully. Send a box of chocolates as my consulting fee. Any materials supplier will have nylon bar stock.
Shooting . . .
s mackay
When I was shooting (injection molding) auto parts I think I rmember nylon "flowed" at around 450-500 F (depending on the alloy). The higher the talc content the higher the temp. Up 'till there it won't leave a taste either (PLEASE don't ask how I know that one). Its also used for a lot of parts in commercial dishwashers and such. If you get "tempered" stock (any rod you might buy from a supplyer is most likely tempered) it'll go through the wash no sweat.
Re: Shooting . . .
Edward in Vancouver
O.K., thanks. Nylon looks like a good bet. Couple of plastic suppliers in my area, so I'll be checking them out.
Next item on my 5 year "round-to-it" list is a "guitar". This is a contraption nicknamed a guitar by pastry chefs and chocolatiers because it used to use guitar string. What it is, is a heavy s/s frame with evenly spaced guitar or s/s wires under significant tension, it is mounted on one end to a table with a perforated base. Not much force is needed, and it cuts perfectly spaced chocolate centers. Same kind of idea for cheese and butter too. Commercial ones go for about 3 grand, with four included frames of different spacings.
It's dream stuff though, I'd be better off buying one than making one, and the fames have to be extremely robust; if you think about it, there would be strings every 1" or closer, each one with significant tension, and the frame about 20" square.
Re: Shooting . . .
TD
I'm assuming those are the light end strings, and possibly not up to tension, that would be about 3 guitars worth which would be 600 pounds which isn't a ton of weight. It would be possible to make that out of wood and just coat it with glass. But stainless would be better. Welding the frame would make sense, and welding is not all that expensive, but it would also be possible to get say some 1x2 stainless tubing, and run threaded rods through the sidebars to pull the ends tight, if you absolutely couldn't locate a cheap welder. The wires can be looped over protuding screw heads, etc... How to tension the wires is another mater, would depend a little on the actual tension.
A impler version might possibly be made like a miter saw base. The base could be something like table saw scored HMWP, the sides could have a comb on them. Then just string one wire on a bowsaw... But maybe there is already a faster way of doing it one at a time.
Stainless ? . . .
s mackay
Find a shop with a bending jig who could machine out the slots for the strings after bending ? It'd might get kinda involved but better than three grand. AND it'd be YOUR way !
Re: Stainless ? . . .
Anon
LV has wire tensioner that would work for tesioning the strings on the frame.
