New WoodChat!
Building a taper or reamer
StephanieSuesanSmith
One of the wonderful things about woodworking is the way you can bootstrap your way to better and better tools and in the process learn a great deal about the craft of woodworking. I am transitioning from doing scroll saw work almost exclusively to working on bigger objects. The first stop to a new fence, for example, is a shaving horse so I can cut the bark off the oak posts. Then they will not rot as fast.
In the case of the shaving horse, I am using a plan that requires the tenons inside the bench portion of the project to be tapered. This is done with wooden chairs and some other things. A pilot hole is drilled and then a taper or reamer, the name seems to vary, is turned in like a corkscrew to create the correct taper.
As you can imagine, there is not much call for this any more in Texas, if there ever was, or even in the United States. The examples I found were either shop made and not for sale or proper copies of old ones designed for use by people in those living history places. These were priced accordingly -- very expensive. I do not do "very expensive." Not, at least, without months of scrimping and saving.
Since I was working in oak, I decided to make a reamer out of a harder wood that grows wild on my place -- osage orange, or bois d'arc, as it is called around here. It is very hard and very durable. It also has thorns and was used to make hedges to keep livestock in before the advent of barbed wire, which makes harvesting it a bit dicey.
I cut a sapling down that was about 2.5 inches in diameter. Here you see a picture of an older tree, and of the sapling once the bark had been peeled off. The bark pulls off easily and can be removed in strips and woven into rope or cord. The Native Americans used the limbs for bows and wove bowstrings out of the bark, hence the local French name meaning "bow wood".
To construct a reamer, you need a cone that is approximately a foot long, with one end a point and the other end two inches across. This forms a 12:1 taper, which was suggested for this use. Some people use a 6:1 or 8:1 taper for chairs. I have not gotten into chair making yet, or other furniture.
Cutting a cone out of a cylinder with a bow saw is not very easy. You cut a wedge in one dimension. Then you stand that wedge on its' side and cut another wedge. A vise would help, but a stopping block and a C clamp does in a pinch.
Once the cone is cut out, it must be sanded smooth. Use one of the pieces left over to craft a handle and drill a small hole through the top for that. I cut a kerf into the cone and set a coping saw blade in it anchored with epoxy as a scrapper. Then I burned the size measurements into it so I didn't have to keep measuring.
Does it work? Yes and no. I did not get the cone perfectly cone-like when sanding, so it is a bit bumpy turning it. The coping saw blade is really too fragile to scrape iron oak, but a hacksaw blade is too wide to fit. I ended up using it more like a ram, tapping hard with a mallet, to make the hole taper. That worked, but it took a lot of effort to wiggle the reamer free after doing that. Wacking on the other side of the reamer is out because it would break the point. So, maybe some design flaws for a wooden reamer, but it did perform the function it was supposed to and now I am working on making the tenons for the legs. The bois d'arc wood is very pretty, too, but stains everything it touches when wet.
As a bonus, the pieces I did not use are serving as wedges for splitting logs. I start the split with an iron wedge and use the wooden ones to keep it open while I move the iron wedge.
Re: Building a taper or reamer
Are you asking for input/help or just posting info
Bob Hackett
Re: Are you asking for input/help or just posting
I had asked about using this, and was showing how I made it. Suggestions, feedback, better ways to do this is welcome. I am trying to learn, so advice is welcome.
TD
The in field version I made was just finished to spokeshave finish. It doesn't mater if it is sanded or otherwise perfect. The saw does the cutting, all the tool does is hold it centered in the hole and suppress chatter. The conical wooden tool could be square in section and would still work just fine. Other than the wood problem, from what I recall the teeth were also removed, this reduces effectiveness a lot and possible particularly on harder woods. The teeth act like a toothing plane and score the surface and ease the passage of the scraper. If it's not cuttin it ain't nuttin.
Larry Barrett
You say you cut a kerf and bedded a coping saw blade.
The main improvement I can suggest (and this was described in the Greenwoodworking article by John ALexander that I think you said you had seen) is to cut a slot the entirely through the reamer and use a keyhole saw blade, which will likely have the correct taper or at least can be filed to have what you want. The blade should project through on each side slightly more than the reamer, so, as Tom says, the blade is doing the scraping and the reamer just holds it more or less in place. Sharpen the non-teeth side and then turn the edge as you would a scraper. Keep the teeth on the other side; they help with the scraping action.
Pam Niedermayer - Austin, TX
Larry, I don't see how a keyhole blade would be wide enough to span the reamer. Did you mean to use the keyhole on one side and a scraper on the other?
Pam
PS Stephanie, where in Texas are you?
Larry Barrett
Pam
I do mean to use a single saw blade to span the reamer. Jennie Alexander calls it a compass saw in this article, I called it a keyhole saw.
Here is a link to the article:
http://www.greenwoodworking.com/SawSteelTaperedReamerPlans
Yeah, I read the article long ago and was suggesting that while there may be compass saws of sufficient width, a keyhole saw is different and not sufficiently wide. And based on an ebay survey, some saws described as compass may also be too narrow.
Pam
Larry Barrett
You may very well be right about finding a saw that will work. I have made and used a couple of these reamers but don't remember where I found the blades; I may have had them for a long time. I just measured them. One is 10" long (the tapered part) and the saw blade is 1 1/4" wide at the top; the other is about 7 1/2 " long and the blade is 3/4" at the top. I used the larger one to make a shaving horse like the one in Alexander's article, and to make several chairs.
The reamer experiences a severe twisting force, particularly when getting started, because the tapered reamer is going into a straight hole, so it is touching only at one place at first. After a few turns, the hole starts to take on a tapered shape and the reamer has more support. Both of my reamers have a permanent twist to both the wooden part and the saw blade after using them quite a bit, although the twist does not effect their performance. Having seen these in action, I think narrow blades (like coping saw blades) would have to be really firmly embedded in a slot to work.
You're right, coping saw blades would be hopeless; however, keyhole saws I have have very sturdy blades, nice and thick. It's a pity they're not wide enough for this job; but it would be fun to try one naked, not surrounded by wood. Think I'll put that on my list.
Pam
