New WoodChat!
Disassembling Old Furniture
Mark Salomon
It was suggested by another forum member that I might try posting this on the hand tool side for their expertise. Thanks in advance.
I have an old Limbert rocking chair that is pretty loose in some of the joints. As a consequence it squeaks alot when I rock in it and it's distracting. I'm toying with the idea of disassembling it, cleaning it and regluing it. I assume that it was originally put together with hide glue. Is anyone aware of a primer or overview about how to proceed with this? I realize that heat and moisture will loosen hide glued joints but how exactly is this done with something as large as a piece of furniture?
Re: Disassembling Old Furniture
Pam Niedermayer - Austin, TX
You don't have to unglue the whole piece, just the smallish joints. You can always get a syringe from LV for injecting hot water (if the joints are really hide glue); but since a lot of them are already loose, why not first try bashing apart with a rubber mallet and/or clamps that you can set up to disemble?
Pam
Some of the plastic-bodied trigger-action bar clamps can be reversed to be pushers. While these clamps have their limitations in furniture assembly, the flex inherent in the plastic body should make them good disassembly "clamps," providing some gentleness in the pressure. In general, don't try to get there all at once; glue joints will give up their bond bit by bit.
Examine the construction of the chair and think about sequence; you don't want to open up a joint in a way that will stress another joint in shear (across the joint).
Jack Guzman from Maine
For a guide I use "Furniture Repair and Restoration" by William Cook and sons. I haven't figured out how to get the hot water into the joint where it matters, but for hide glued joints,injecting alcohol into the joint loosens up the glue bond by breaking down the glue.I usually take the whole base of the chair apart when possible. If one joint is loose chances are another is close to failing.I clean and reglue all joints.To get stubborn joints apart I rap firmly with a metal hammer using a block of wood against the chair part to prevent dings. Reversible clamps are another method.Sometimes I put pressure with the clamp and then strike it. Rocking chairs usually come apart fairly easily.---Jack
