New WoodChat!
Step by step rosewood tote repair
Dominic in Buck's County PA
Hi gang,
Back about a month ago I was on WoodNet asking for a suggestions on a suitable wood to use for repairing a rosewood tote. I was advised to use walnut, along with some other easier to obtain woods. However, I also received a couple emails where some guys offered to send me a chunk of rosewood. I accepted and used a couple small pieces to repair this rosewood tote.
Now before you ask, ,"Why go through all this mess? Just make a new one!", I'll give you MY reasons.
  • First off, I really don't like making totes. I can shape them pretty easily, but I consistently mess up the drilling for the counter bore at the top. The only way I can see to make it full proof is to buy a counterbore bit. And I have one of them on order now. But it'll take some time to get here.
  • Secondly, when I'm restoring an older handplane I like to retain the original rosewood just to keep a measure of "authenticity". Sure a walnut tote will look authentic. But those old rosewood totes had style. And they look so cool once they are cleaned up and refinished!
  • Thirdly, I hate to throw out a rosewood tote, or cut it up for scrap just because it's got some dings and cracks. The old timers used rosewood for a reason. It looks awesome and just carves so beautifully!
  • So here we go:
    Here's a shot of the tote. Notice the flat I made at the top of the horn. That's where a major chip was. And take a look at the front mounting hole. The front is missing and no amount of tightening would stop this tote from wiggling.
    I use 2 part epoxy that you can buy from Home Depot. I chose epoxy because it makes a more flexible bond than CA Glue. The cup is for containing and mixing the glue. It also acts as a nice way to catch the charcoal dust that I use to color the epoxy.
    In order to fix the front of the tote, I needed to do the patch in two parts. One to give me a base to work on and one to affix a new "toe" where I could new drill a hole for the screw.
    I planed/sanded a flat for the patch and then wiped the area down with mineral spirits (just to clean away excess oils). After that I found two suitable pieces of rosewood and then planed/sanded a flat on them as well. The patch area was given a coat of colored epoxy and then the pieces were clamped in place. I allowed them to dry over night.
    This is what it looked like the next day.
    Now that I had the first patch(es) glued in place, I could shape the parts.
    I used a rasp to get the surfaces as close as possible and then decided it was time to clean up the "toe". A small incision was made using my dovetail saw and then the broken portion of the tow was parred away.
    I then repeated the process for gluing in the patch.
    The next day I used my rasps to define the overall shape.
    And some scrapers and sandpaper to clean up the rest
    And then gave both the knob (which was cleaned and sanded) and tote several coats of TruOil
    After some buffing and waxing, the tote and knob were installed back on the plane.
    That's pretty much it. The colored epoxy blends into the surface and you can hardly see that patch.
    Thanks for viewing.
    See ya around,
    Dominic
    Re: Step by step rosewood tote repair
    Moses Yoder
    Moses Yoder
    Your tote looks pretty good. I normally bore a new tote before shaping it. I draw the tote on a board then cut to rought shape with a band saw. To bore a new tote, I normally drill the counterbore at the top first with a brad point bit, then draw a line where the through hole will go, drilling halfway though from the top, then drilling from the bottom till I meet the hole at the top. Another good thing to do is to find a box full of totes at a garage sale for $5, but I suppose that's kind of rare. Although I do know it happens ;)
    That's a nice blow-by-blow, Dom!
    Bruce, a MN Galoot
    Thanks for posting. I'm curious, though, why you didn't cut off and replace the whole bottom end instead of just the front part. It might have been less work, but then I'm just guessing.
    Very cool Dom, have you tried...
    Scott Burr in Ben Lomond CA
    Reshaping the totes to fit your hand better?
    I've adapted my totes by eliminating the "hot spots" I experience while planing. Look at my pics and you'll see who a reduction in radii make a more comfy tote. Well, for me anyway..
