New WoodChat!
Clogging problem in a wooden plane *LINK*
Kees
My first post here. I've waded through the archives and there seems to be a lot of expertise about this subject on this forum. So I hope to get some pointers from you.
At the moment I'm trying to make a wooden plane in the traditional manner, morticing beech stock and fitting a wedge. It is going to be a small 55 degree single iron plane. On my blog (link at the end of this message) you can see some pictures of my attempts. Of course there are lots of mistakes and I ended up with a huge mouth. Nothing too bad for a first try, but now I've stumbled into a problem where I can't find a solution. It's clogging badly in one corner, the left one in the picture. It seems that woodfibers get hooked in that corner between the wedge tip and the side of the blade.
Does somebody have an idea how I can solve this problem?
http://seekelot.blogspot.com/2011/04/schaafje-maken.html
Re: Clogging problem in a wooden plane *LINK*
TD
I didn't look at the blog. So I hope this helps.
Often that kind of problem has an origin in the wedge being too long. It sorta seems as though the wedge could vanish near the mouth, but in practice it doesn't need to come down all that far, so just check against antiques, etc... to see whether you have overdone it. The other thing is to ensure the wedge is full width at the points. I start with wood that is a little wider, a few shavings, than the mortice. Then I plane away a bit behind the points. Once the points are are tapered and sharpened, they are a spring fit to the sides. This is a subtle thing, I don't have to use two hands to get the wedge in or anything, it is pretty normal all around. It is just being sure they are trending to the outside rather that the centre line.
Kees
Thanks a lot for the ideas. I'll try to shorten the wedge first and maybe polish the wood a bit to make everything smoother. My wedgepocket sides are also still a bit rough, so it is kind of hard to get the fit you describe. I am now at the point that everything gets sloppier the more I do. This plane is probably not a keeper, but it is good practice and i would just like to solve these issues before I start in earnest.
Moses Yoder
Moses Yoder
It looks like your iron is substantially narrower than the mouth. This will cause problems in adjusting the iron laterally, and also cause the clogs you have. The shavings will go across the iron at a slight angle and catch underneath the wedge beside the iron. The iron should only be about 1/16" narrower than the mouth. I have made several Krenov style planes where the body is laminated; this makes it a lot easier to build than a 1 piece plane.
TD
I still use a couple of my earliest planes, that were pretty sloppy. Planes that have a huge mouth will be among the most useful you own, and can connect you for decades to your earliest efforts. If you took too much away, ad some lams, if you left too much just keep refining.
One thing I didn't mention that will solve your clogging problem and make better use of your big mouth, is to camber the blade. Gives you that sexy scrub or jack type attack, and will keep the shaving away from the edges of the wedge where the jamming problems are located.
kees
Yes, the mortice is definitely too wide for the iron. So maybe I will also add a lamination in the wedgepocket. Good lesson for the next attempt. Somehow the iron is always wanting to settle on the right side in the pricture and I don't get clogging there.
kees
The problem with changing this plane into a scrub like one, is that I allready have a shelf full of antiques with wide open mouths :D That seems to be their natural state of being after all these years.
