New WoodChat!
Disston Disapointment . . .
steve mackay
This had been hanging in my FIL's garage since I've known them. Probably 50's D-23 cross. Less handle and only four nuts. They were "crafters" and I KNEW the fate that was in store for it. After years of lusting it finally followed me home before it was humiliated with a pastoral farm scene. My heart broke when I started removing the rust and gunk. It had already been "prepped" for it's new look. With, probably, 80 grit on a belt sander. 220 made no headway. 150 neither. Any bigger grit and it'll be paper thin. I know it's not worth a whole lot of effort but it deserved a better fate. It will have to live on as scrapers and such.
Let us all bow our heads . . .
Re: Disston Disapointment . . .
Before you cut it up...
Bob Hackett
Try sharpening it,waxing the sides and giving it a go. You may be surprised.
File of choice ? . . .
steve mackay
I'm not trying to be a smart alec but every time I ask someone how to get started sharpening I get a REALLY long, detailed, exhaustive description. I've read the procceses on line and such and I tend to get lost without actually doing it. Are there ONE or two files I can go get, sit here in front of the monitor and follow the directions, and get a BEGINER'S feel for it ?
Re: File of choice ? . . .
Bob Hackett
Not knowing what the teeth look like I can tell you that the guidance I`ve gotten is to be sure the file you use is a little over twice in width of each face of the depth of the gullet (height of the tooth). as an example;if your tooth is exactly 1/4 inch tall on the cutting face then your file will want to be slightly over 1/2 inch wide on each of the 3 faces(saw files are usually triangular for these types of saws).
To give you a size to order from a catalog to match your saw I would have to direct you to someone like Marv. I usually go down to the store with my saw if I need a file size that I don`t have and match it up if the guy behind the counter doesn`t know off the top of his head what I need. Even if he does,I still check it against the saw before I leave.
Then again I also bring an old spark plug from the car I`m tuning up when going to get parts. Everybody can have an off day and it always pays to have a visual reference handy to check against. :)
TD
Have you watched the Tom Law video. I think I have it somewhere. Or maybe it is online these days. New files help.
steve mackay
So, there's really no one or two files I can pick up at Sears or a Borg ?
Will this help get me started ? . . .
steve mackay
. . . or are vises specific to saw type ?
Re: Will this help get me started ? . . . *LINK*
Larry Barrett
That will work fine for any saw.
You can rent the Tom Law video here (and many more of possible interest).
Smartflix
Bruce, a MN Galoot
that looks to be the same kind of saw vise that I have, Steve, and it works just fine.
For starters, though, I would recommend not over-thinking this whole process. What I did the first time out was just set the file next to the tooth and adjusted the angles until they matched what was already there. While there's no doubt that those first efforts can be improved upon, that saw turned out so much better than it was when I got it that I haven't taken the time to learn the stuff to really spiff it up.
AHA ! . . .
steve mackay
I just KNEW there would be a "short answer" . This I can do. Now . . . what file do I ask my Tool Lady for ?
Files *LINK*
There are any number of places where you can find tables that tell you file size based on saw tooth coarseness. Tools for Working Wood built it into their catalog listing of files, linky below, but you can find actual tables by Googling "saw filing" and poking around a little in the resulting links (on the "Saw Filing Treatise" from Vintage Saws that comes up first, it's about five paragraphs down).
Note that a lot - maybe most - of these tables discuss "ppi," meaning "points per inch." This is subtly different from "teeth per inch." If you count "teeth per inch, you have to count the full with of each tooth. If you count "points per inch," you set your rule on the point of a tooth and count teeth until you hit the inch mark, including the tooth (if any) on which the point hits the inch mark. This usually results in one more point per inch than tooth per inch.
http://www.toolsforworkingwood.com/Merchant/merchant.mvc?Screen=PROD&Store_Code=toolshop&Product_Code=EE-555-SF.XX&Category_Code=TH
Roger Nixon
Saw file size depends on the tooth size or teeth per inch on your saw. If it hasn't been tampered with, the size is stamped on the heel of the medallion side of the saw.
Here is a chart that shows appropriate file sizes :http://www.toolsforworkingwood.com/Merchant/merchant.mvc?Screen=NEXT&StoreCode=toolstore&nextpage=/extra/blogpage.html&BlogID=86
Marv
Hi Steve,
Buy a file that is as close to twice the size of the back of the tooth, not the cutting edge.
The reason is, due to the rake angle, the back of the tooth will be longer than the cutting edge or front of the tooth. The main reason for twice the size of the back of the tooth is so you can use the file more efficiently. If the sides of the file is less than the back of the tooth, the wear will over lap during the life of the file. However, if you will only be filing the one saw, it's no big deal, but you don't want to go any bigger because the bigger the file the more rounded the bottom of the gullet will be which will make the gullet not as deep. You want a gullet as deep as possible and also have a small radius at the bottom.
Are your eyes starting to glaze over yet? *smirk*
The reason you always get long winded instructions regarding filing saws is because there are no short cuts that will produce the best results. It's like learning to walk.... you learn to put one foot in front of the other and if you keep doing it, first thing you know, you'll be walking.
I'm reminded of George Burns....When George was in his 80,s, he walked two miles a day. Someone asked how he did that at his age and he replied...well, ya see, I put one foot in front of the other, then I put the other foot in front of the other and then I put the other foot in front of the other and when I keep doing that, first thing I know, I'm walking. However, as far as I know, he never filed a saw. :D
Marv
Seeing the light ! . . .
steve mackay
I'm starting to see the light. Sounds like it ain't alchemy BUT one size doesn't fit all. Just for kicks I went to my "go-to" source, God bless 'em. Mr. Lee sells files acording to the number of teeth. Doesn't get much easier than that. Running out of excuses now.
Now if whoever is bidding on that Disston saw vise would PLEASE knock it off I'll be in bussiness ! :(
By the way, Steve,
One of the good things about using this saw to try sharpening on is that it's not a rare, kind of valuable model. They can be perfectly serviceable saws; but if you find it hard, you won't have ruined something that you'll kick yourself over.
It's kind of like it was when I was young with cars: you didn't learn how to fix cars by fixing your dad's (hypothetical, here) Jaguar; you practiced on more working-class cars first.
Plan B
Bob Hackett
Look thru the archives for Dom`s excellent home brew saw vise if this one goes thru the roof.
I was just about to ask . . .
steve mackay
if that could be done. While the files do NOT cost a fortune . . . I'd hate to have a fifty dollar rig sitting around after I discover this sharpening thing is beyond the GI mentality. :D
You can always sell good tools.
Pam Niedermayer - Austin, TX
I agree!
Doug Trembath
I built one like it, inspired by Dom's article. He does a great job with drawings and explanations, too. I remembered one similar to Dom's, in a book or magazine from the past when Dom brought his out for show, as well, but there are simply too many to go through looking for it. Mine's a bit different, but it was Dom that gave me the impetus to finally get one built. Works great, too!
Doug Trembath
