Re: Update on The Blade.
Why use a lever cap instead of a wedge? Perhaps because you had a lever cap laying around? Seems like a wedge would hold the iron better.
Hi Moses
Originally I planned to use a wedge. Indeed, the pictures you see are of Mk2. Mk1 had mortices for a wedge.
Then I examined the blade carefully and discovered that the wedge-side of the blade was not coplanar -probably because of all the work done to lap it flat. This meant that a wedge could not provide even pressure along its length.
At the same time I recalled the lever cap that Peter had given me, and this seemed to me to be the answer since the lever cap would not be affected by a blade lacking a coplanar surface. Note that the back of the blade - the side that rests on the bed - is both flat and coplanar. Without that the blade would rock.
Another amateur question, hold did you fill the groove in the iron; it looks like brass, but how is it stuck in there?
The blade is designed to use a cap iron. While it could be used without a cap iron with a wedge, the only way I can work with this blade was to use a lever cap. And the slot would made it impossible to use a lever cap without a cap iron. I didn't want to use a cap iron as I believed that the blade was thick enough. I did, nevertheless, make a cap iron (out of some of the hardest brass I have ever come across). I did not like the effect. So I chose to infill the slot. I have done this before...
A 3/16" Hock blade used in a jointer ...
I simply filed a piece to fit fractionally oversize, then peened it in. A little epoxy was added to the rear for good measure (as the 1/8" brass is not as thick as the blade).
And I just have to ask, although it is not April 1 it is still April, is this some sort of April Fools joke? Or perhaps you didn't have it ready for April 1?
Believe me I thought of it!
But, no, it is real. And I'm hoping that it will get good use.
