New WoodChat!
The Veritas SemiFill Smoother - early review
�SemiFill� is an abbreviation of Semi Infill. In response to repeated requests for an infill smoother, the SemiFill serves to build on an existing platform, the Bevel Up Smoother (#164 �).
Article here: http://www.inthewoodshop.com/ToolReviews/VeritasSemiFillSmoother.html
Re: The Veritas SemiFill Smoother - early review
Phil Smith
Are you going to fit the plane with the new C3PO 2BRNT2B plane iron with the Mac Alister tartan up to see if the extra mass improves performance. This could be an exciting development.
anotherBob
DDN
(date duly noted)
Roger Nixon
No kidding, Derek, it looks like it would work. Does it really?
Hi Roger
Does it make shavings? Yep. Is it any good at doing so? Nope. Actually, it is difficult to say - the infill needs to be glued in, or secured in some way. As it is, it has sandpaper underneath to act as non-slip, but this is not fully adequate. As a result the blade slips a little and it is not possible to obtain a stable depth of cut.
On the other hand I have built a plane like this. It does have a 25 degree bed ... and it is one of the finest smoothers I have used.
So it is more than just possible. :)
bugbear
But can it take the "thick blade" ?
BugBear
Hi BB
It can ... but the combination is so tall that you cannot see where you are going.
Until next April 1 ...
