Gorilla Glue
Jack Guzman from Maine
Unfortunately some people consider this stuff the best thing ever invented . One fool in particular caused me a bit of work.
My wife bought a "new" bed at a flea market. The headboard is walnut and it has some nice molding details. The only problem is that the previous owner decided to reglue it. Below the crown piece are four rails with floating panels between them. This unknown regluer was very generous with the glue. This person took the whole piece apart and glued every groove generously. When I got it the back was covered with foam from excessive amounts of glue. The panels were permanently attached to the rails. Obviously ,no clamps were used because the posts were pushed apart by the expanding adhesive. I tried using heat and a putty knife to separate the panels. I sliced into each groove to the bottom,but the panels still broke trying to get them out of the grooves. I finally decided to give up on trying to save the panels intact.
I cut each panel at the edge of the rails.Then I cleaned the glue and wood out of the groove with a chisel.To make up the loss of width I discarded one rail and built a new,wider one. Glued back up correctly the bed is ready for use and not too bad considering what it's been through. A little stain on the new rail it is a nice looking headboard. My wife is happy and I have another humorous story about what not to do.---Jack
