New WoodChat!
shooting edges
shooting edges
shooting edges
Jerry Gibbs
Was at a wood show today and the saleman said that wiping mineral spirits on the board edge made shooting the edge easier. I had not heard this before. Is this a well known trick? Jerry
Re: shooting edges
I mean ends
Jerry Gibbs
Re: shooting edges
I've seen other references to it
Re: shooting edges
Re: I've seen other references to it
Pam Niedermayer - Austin, TX
Yeah, me, too, but only during the last week or two. Must have been a lot of people at that show. :)
Pam
Re: shooting edges
Re: shooting edges
TomD
Well in general re-wet wood, or wet wood are easier to cut. It does beg the question just how dull is the blade or hard is the wood. More typically I would simply adjust the depth of cut. Wetting can make sense if the wood would otherwise tear out. Say some birdseye.
Re: shooting edges
Re: shooting edges
Dan Donaldson
In this case, since it is mineral spirits that are being used, if there is any effect at all, maybe it is due to a lubricating action of the solvent on the wood.
Re: shooting edges
Re: shooting edges
Brian Greene
Wetting the end grain with alcohol or mineral spirits softens the wood fibers, making them easier to slice cleanly. It's an old trick.
Re: shooting edges
Both Dan and yourself are on the right track...
Scott Burr in Ben Lomond CA
MS raises and "plumps" the grain a bit to make end grain a bit easier. I've only had to use it on screwy wood like curly and birdseye maple and some jungle woods myself.
Re: shooting edges
Chris Schwarz mentions alcohol
Chris Friesen
Chris Schwaz has mentioned using alcohol on end grain in a number of different articles. He claims that it softens the fibers and makes them easier to plane.
I'd imagine that mineral spirits would do the same, but it would likely take longer to evaporate. This could be good or bad depending on how much of a hurry you're in.
