New WoodChat!
THE WOODRAT IS BACK!
Enduro-var
Enduro-var
Enduro-var
TomD
Has anyone tried this?
Shelf life after it is unsealed.
Adhesion.
Any reports at all?
Re: Enduro-var
Re: Enduro-var
Tony - Memphis
I have used it. I like it. I've only used it on some raw cherry and maple. No issues. It polishes up almost too well! I used it on some turnings and they came out too glossy! I am going to keep evaluating it on other applications. It is a bit pricey. As with other water based products, work fast and don't overwork it.
Tony
Re: Enduro-var
Re: Enduro-var
TomD
Thanks Tony. Not my personal preference, but for guitars there is no such thing as too glossy in the eyes of many. :)
Re: Enduro-var
Re: Enduro-var
Paul M.
Hi Tom,
I have not used this product. But I would question the use of urethane for Guitars. Most builders use either Lacquer or French Polish. I would be hesitant for using Urethane due to witness lines seen during final rub-out on Urethanes if you happen to get through the top-most layer. Have you had success with other urethanes as a guitar finish?
I know that many high-volume guitar shops use urethane, but they are more worried about warranty returns than they are about sound quality. They need a thick plastic bullet-proof finish to keep their prices down and increase their margins. For a custom builder, that volume equation does not have as much pull.
Re: Enduro-var
Re: Enduro-var
TomD
I wouldn't use it on the soundboard, at least not for now. I am not a big believer in resonance in the back, though a lot of people swear by it. I built some guitars early on with two soundboards, and I kinda lost interest after that. At the other extreme there are guitars with heavily laminated backs and sides, and they could care less. There are some pros who will need weekly maintenance on an FP guitar... :)
I got interested in varnish recently, because I have a long history using the stuff, and I want something for people who want a really plastic shine, and varnish is now in. I gather that a lot of the stuff that has been water based in the past, has been a big disappointment, and nearly bankrupted some builders. But the nature of synthetics is they eventually get it right. Crosslinking is normally a big step in the right direction. Your comments about sanding through are apt.
I am also interested in just having some of this stuff around. It might for instance be a rod wrap varnish for fly rods. It sounds very space age. But that is my concern relative to shelf life. 30 bucks is reasonable if it will hang around and do some high end things. But if it it blows up within a month of cracking the can... Unfortunately I have so many directions it is bankrupting me to try out everything I would like to try out.
