"Older (bevels) were so much better" rant (rambly)
At a garage sale recently, I picked up a Stanley adjustable bevel (aka, "T-bevel"). I thought I was buying it to donate to Habitat (and, well, it was there and 50 cents). But, when I got it home, I took a closer look at it, and was struck by its construction. I happened to have a newer one (definitely headed to Habitat), purchased as part of a box lot at an estate sale a few months ago, and, comparing the old with the new...the old wins.
Here's the front of the two bevels. The larger one is the older. This type of bevel works best when the tightening lever hits "tight" when it's tucked into the body of the bevel - so that it doesn't interfere with its application to the work when flipped over (tightening is clockwise).
No big difference, right? It's the back where the differences show:
Note that the older bevel has a nut on the shaft for tightening the bevel. This nut is tight on the shaft - some kind of deformed-thread nut, I think - and allows precise adjustment of the tension, so that the tightening lever can be both optimally tight and inside the body.
In contrast, as shown in this picture, the newer one has a hex carriage bolt that allows a limited range of adjustments. When the lever is tight on this one, it's nearly out the far side of the body of the bevel.
In addition, the tightening lever on the older bevel is staked on - the threads deformed, so that the lever doesn't want to come off - so you're less likely to lose parts. The pictures aren't as clear as I'd have liked; the sides of the clamping "bolt" on the older bevel are flat, with matching flat sides on the back hole.
The older bevel is marked with the Stanley logo used from 1885-1907, and has an 1897 patent date on it - so I take it that it was produced some time during the decade 1897-1907. To be fair to Stanley, the newer one is marked merely, "Made in U.S.A."; but it looks remarkably like later model Stanley bevels I have seen.
Even if the newer one's not a Stanley, though, the point remains: the design on the older bevel is far superior to later designs of this lever-clamped bevel.
It's such a well-thought-out design that it migrated into my layout tools drawer, where it can make friends with (I blush a bit, but they were all cheap) six other bevels of various sizes.
And, yes: there are cooler designs out there, like the Stanley 18; I happen to own one (and also a Craftsman based on the same design). But I have space in that drawer...
