chair repair
Bruce, a MN Galoot
I posted this on the main board, but I just realized (I'm on night shift, brain doesn't work so well) that there are probably more fixers on this side.
I'm fixing up a basket case chair for a friend. Every joint on the thing has to be re-done. The seat rails are doweled into the legs, and a couple are broke off, so since there is enough wood I'm routing out the dowels and replacing them with floating tenons. That's pretty straightforward.
The question I have is about the stretchers. They are doweled as well, but there's not enough wood to drill them out and start from scratch. Besides, the holes on the legs have been glue and re-glued, so they need to be scraped out, and maybe drilled before I get to useful, clean wood.
I plan to wrap the dowel ends on the stretchers with veneer and let the glue set up before final fitting. Is paper a valid substitute for wood veneer to wrap the dowel ends?
Or is there another technique I should use?
Thanks
