New WoodChat!
LN Jack Plane Kit
LN Jack Plane Kit
LN Jack Plane Kit
Jerry Gibbs
My wife owes me big time. Is the LN low angle jack plane kit at $500 worth it? I am a hand plane newbie.
Re: LN Jack Plane Kit
David Barnett
Some things to consider
David Barnett
Since you're a newbie, as you say, I'd opt for the plane without the extras. Plenty to learn with the one plane and a single blade. You may never even use that hot dog handle. You could get two planes for $500, of course. A smoother and a small block plane can be useful, too.
Remember, you'll need to sharpen your blade, so you may wish to consider your outlay for that; a grinder, stones, a jig, as well. Lots to say about sharpening. You could search the archives or ask in a new thread. Sharpening comes up from time to time on the Hand Tools side of WC. Some even have fairly strong opinions as to what's best and how to get going.
Re: Some things to consider
Pam Niedermayer - Austin, TX
I agree, get just the plane, with maybe a toothing blade if you plan to prepare stock (vs buying already dimensioned boards); and add to that some way of sharpening the blade. You can start with sandpaper on a flat surface. Then you'll be up and going and have some empirical basis on which to base further decisions.
Pam
TomD
Why would you use a toothing plane to prepare boards? I use it for planing woods that will absolutely tear out for sure when cut, and needs to be worked down? Is that what you use it for? But it is a rare thing for stuff like Birdseye of osage . For most part I would use a cambered jack at 45 degree to the grain.
I'm sure you meant diamond paste, Dave...
TomD
Not worth it at all. I looked and looked before I could find what was in it. If it was me, I would buy the smoother and the jointer and not bother with the Jack. I have an LN LA jack and it's a nice plane, but a newbie with 500 or so in his pocket is going to get a lot more use out of a smoother and a Jointer. Or you could just buy the jack. The accessories package is not composed of bedrock stuff.
There is a reason why each of these planes exists, and why you might collect them, but a jointer and smoother would be first on my list. I have the LV jointer, and the LN jack, in LA planes. Regular jointer was the first plane I bought 30ish years ago and is the only one of my earliest planes that I bought that I still use all the time.
For me a jack is a stock removal plane, so the delicate features and weight of an LA are kind out of place I want to take shavings about half the thickness of the plane blade itself at times. My preference is way over the top for a wooden plane in that role.
Seems easier to hit the high parts with the toothing blade.
I started doing this based on a tip from Chuck, who's no longer here.
Pam
