New WoodChat!
The Stair Saw Project
Dominic in Buck's County PA
Hi gang,
I just started working on a new project in which I will build a stair saw based on an old Disston Stair saw loaned to me by Buckaroo from Woodnet.
I drew up the profile and made myself a temple of the handle. I also took the time to draw up a profile of the saw plate and get it's measurements down.
I used a caliper to measure the thickness of the sawplate and was sort of surprised to find that it was 0.032" thk. But I guess this would stand to reason since you would want a stiff saw plate for cuts where it was extended away from the handle.
Before really digging into the building process, I like to get all the raw material together and cut to rough size. Tonight I started on the saw plate.
I dug through my pile of spring steel and located some that I had already "de-blued". While it is easy to remove the bluing via a citric acid bath, that's one step I didn't have to do this time.
I coated the steel with some dye chem (notice the protective surface I'm working on?) and then pretty much traced the original saw plate.
laying out the saw plate
As far as cutting the spring steel to shape, here's the process I've been describing in my recent write ups. And I realize that there are many ways to accomplish this task. But here's the way I do it.
I use a Dremel equipped with an abrasive disk to cut along the scribed line. I cut along the line, being careful not to linger in one place too long, and not to go all the way through. My goal is to score the surface just enough to enable me to snap it at the cut line.
Scribing the line
I then take the work piece and install it in my vise. I clamp it in place so that the scored line is right at the top edge of the vise jaws.
snapping along the scribed line
Then it is a simple matter to bend the work piece and the spring steel should break right along that line.
Notice that in this photo I'm doing something rather stupid. I'm NOT wearing gloves! And I wonder why I get metal splinters! In the next cut you'll see that I finally wised up.
As before I will score along the scribed line
Scribing the line
Then place the work piece in my vise. Grab the top portion and give it a push
And break the steel along the scribed line.
A minute spent with a mill file to clean up the cut end and now I have two blanks to make the stair saw plates.
saw plate blanks ready to go
I will continue with them in my next update. For now, it's onto stock selection and prep for the handle
I decided to make one handle from some very nice clear 6/4 cherry I milled up several years ago. It's bone dry now and ready to be used. The second stair saw will be made from some 6/4 bird's eye maple I picked up at Hearne's Hardwood.
handle material
I cross cut both pieces (using my Halfback saw!) to the appropriate length and surfaced them in prep for resawing. The cherry needed to be ripped down to size since it a lot wider than the 5" required. Rather than use my bandsaw, I decided to try out the thumb hole rip that I bought from Woodnet's TablesawTom late last year. It went a heck of a lot smoother than I had expected.
ripping the handle blank to size
That's about it for now. As I work on this more, I will update this thread.
See ya around,
Dominic
Re: The Stair Saw Project
TomD
Some good tips there, thanks. I have a piece I need to bust out, so that is really useful. I may leave the blue on the blade until I get it laid out. They I will use your citric acid trick. Do you buy citric acid for canning, or just rub it with a lemon?
I got a 15lb bag of powdered Citric Acid from a seller on Ebay. It's used in candy and beer making and is "food grade" (BTW, It's also useful for de-rusting tools).
15lb Citric Acid Anhydrous Food Grade FCC/UPC Free Ship
The one tip I'll pass along is use hot to warm water. I was told that for every 10 deg F you raise the temp, it'll work 10 minutes faster. However, I just used hot tap water and a 10% mix of acid to water and it "de-blued" the steel in about 2 minutes. If I work on a batch of steel I will had hot water (as well as little more citric acid powder) to the mix every once in a while to keep it warm
Frank D. in Montreal
Hey Dominic,
Thanks for that. Just one question for now...is that five-gallon bucket with wood on it some kind of a saw bench, or is that just what you happened to have at hand to hold the piece up? Seems like a good idea that doesn't take up a lot of space.
David Barnett
Citric acid pickle, Edinburgh Etch, Gummi Bears. *LINK*
David Barnett
I'd never have thought to remove the blue with citric acid. Good tip.
Fair price with free shipping. I buy 25 lbs for about $50 but I pay freight.
"The one tip I'll pass along is use hot to warm water. I was told that for every 10 deg F you raise the temp, it'll work 10 minutes faster. However, I just used hot tap water and a 10% mix of acid to water and it "de-blued" the steel in about 2 minutes."
Actually, that curve flattens out after 130F or so. I keep a crockpot full of citric acid pickle on the low setting for days at a time, which steeps above 165F, the point at which most bacteria die. It's sufficiently fast and so safe that I now use it exclusively for pickling gold, silver, and copper. Much better than sodium bisulfate (sold as Sparex to metalsmiths, but also used in swimming pools). Very clean, easy on the nose and won't burn holes in your clothes like sulphuric acid.
It's also the second component in the wonderful Edinburgh Etch, a versatile and safe mordant that can be tuned to etch copper, zinc, steel, brass, aluminum and more. Terrific stuff. Might be worth looking into for tool marking and decoration.
Most important, lately, it gives that bite to my homemade sugar-free Gummi Bears. Black currant, pi�a colada (extra coconut), guava -- you can only imagine.
The Edinburgh Etch
Marv
Hey Dom,
Tham's some big teeth on that there lil saw! Is it a rip or a crosscut? :D
What is a saw like that used for other than stairs?
Here's an idea.....
Would it be practical to use that design as a dovetail saw and adjust the blade for depth of cut? Make the length about 10"? And maybe shape the handle more for comfort compared to what we are used to seeing on a stair saw?
Sorry Dom, didn't mean to veer off your subject like that. Well, yes I guess I did mean to, but the idea just came to me out of the blue. Might have been the blue Dykem. :b
Catchalater,
Marv
Why are you always one step ahead me...
Scott Burr in Ben Lomond CA
I'm getting ready to make one myself. I have a rip Disston stair saw and I want to make a cross cut one. At least I'll be learning from you mistakes.
:D
We missed you Dom!
Bob Hackett
Glad to see you back.You always make cool stuff look so easy. :)
Re: Why are you always one step ahead me...
That is because your mind is an open book to the Great Carnac!
Jack Guzman from Maine
bucket bench
I like that. Makes a handy seat for low to the floor work too. Seems like all you'd need is a round block with an inner lip of some sort to keep it in place on the bucket. Store the block on a shelf til needed. Than grab any bucket that's handy.I'm going to make a couple of those.---Jack
Re: bucket bench
Back when I was a devoted wood turner I was soaking roughed out bowls in dishwashing detergent to help "dry them out" faster. ;) I made the lid out of some scrap pine and routed a lip on the side to match the diameter of the bucket. Since that time it's become a shop stool and my daughter's favorite place to sit while she watches me work.
It's sort of a joke with my friends now where they call that my "saw bench". Yeah, it's not pretty. Yeah, it's super cheap to make. And yeah, it doesn't work all that well......
what was I saying again? :D
After this I'm building a REAL saw bench
TomD
Thanks for that. Turns out we stock the acid for making lemonade syrup. Apparently the Bulk Barn has it.
The Stair Saw Project: cutting the profiles
Here's another installment in the "Stairsaw project".
After selecting the stock and surfacing it to the correct thickness I cut out and glued the templates for the body to each piece. Notice that the number of saws has grown from two to three. That's because I finished up drawing the profile for the 8" stairsaw.
The templates were cut oversized so that I didn't loose the locations of the center points for some of the large holes. As you know, drilling the holes makes bandsawing out the profile a good deal easier. You get smoother more accurate curves in that area.
cutting out the stairsaw profiles
After the parts were cut out, I planed the base (where the saw plate extends) and made sure it was plumb to the sides.
That's it for now. Hopefully I can work on this some more this weekend.
See ya around,
Dominic
Nice
Sandor in DE
Love these posts. One recommendation: Use a paste glue stick to glue your pattern down instead of the spray adhesive. The glue stick will hold just fine for the duration it is needed and the residue will wipe away with just some water. The 3M stuff is an excellent product but is a pain to clean up! my 2�
Sandor
Look'n nice !
steve mackay
Stair Saw Project: Cutting the slot & drilling
Hi gang,
Some more stairsaw work:
First I used my marking gauge to mark the saw slot
marking the slot
Then I "blocked" up tenon saw on my bench and used it to saw the slot
sawing the slot
After a short time I have a straight yet shallow cut
sawing the slot
I use my tenon saw to deepen the cut. All the while keeping an eye on the marked line so I don't wander.
sawing the slot
sawing the slot
Using a piece of 0.025" thk spring steel, I test out the fit
sawing the slot
Now that the slot is cut it's time to finish up the saw plates. The holes were cut with my new best friend, a carbide drill bit. Holy MOLY these babies ROCK! :yes: The carbide bit ate through this steel like it was butter. (Guess who is saving up to buy more of these?) The slotted holes were cut with a dremel and smoothed out with a file. Finally the saw plates were sanded to about 400 grit. I will clean them up more before I sharpen them
cleaned saw plates
Now it's time to drill the holes for the saw nuts. I have (2) pair of saw nuts from TFWW and (2) recycled saw nuts from an old Disston saw. But this time I have a secret weapon. It's a 1/2" dia counterbore with an interchangeable drill (Enco# 368-1032). Now, no more fooling around with multiple drills and worrying about off center holes.
counterbore
It took me only a minute to drill the holes for the TFWW saw nuts and about 15 to do the same for the old Disston saw nuts. Once I clean up the saws I will make sure all the saw nuts are flush with the surface.
saw assembly
And here are the assembled stain saws. Notice something funny about the 6" stair saws? Yes, the teeth are set up for the pull stroke. :D I cut the slots reversed from the way they should have been. And you can't flip the saw plate around because the holes are off center. Part of the saw plate will stick out neat the handle. Eh, no worries. It'll all come out right when I sharpen them.
Stay tuned for more.
See ya around,
Dominic
Paul Kramer
nice progress
Paul Kramer
Dom,
Looks good. What kind of carbide drill bits did you use -- anything special?
Paul
Re: nice progress
Paul,
Here's what I used:
Model #619-0850
Re: Stair Saw Project: Cutting the slot & drilling
Pam Niedermayer - Austin, TX
Look very good; but why do you need different sizes?
Pam
Like any other saw...
It's nice to have rip and crosscuts. Some people only think about stairs when thinking about these little beasts. Just because of their name. This type of saw can )and does) excel at dados and a nice shoulder cut, when you can't find another saw. They can undercut base boards.
Hell, I'm just beginning. Throw yer head around it :b
You'll need 2 at least...
What do you want to bet the big CS is going to do a stair saw next if PW.
Excellent Domnick!
Thanks for the write up and all the good pics too.
Yet you are a somewhat evil man for showing me and probably a few others this amateur saw porn.
One can only wonder where this go...
Thanks!
Dominic in Buck's County Pa
Pam,
Thanks for the compliments.
Since I had one to use as a template, I started out by reproducing the 6" version that was offered by Disston. As you would suspect, this size is useful for getting into tight places and working around obstacles (like installing new treads on an existing stringer).
Right after I completed the drawing I ran across the 8" version. Personally, I prefer the longer version because of the size of the projects I build. More specifically I would use this for defining the sides of a dado for case work.
This is also one other (major) reason I prefer the 8" version. An 8" saw plate will fit on my Foley Retoother! The uprights on the carrier bar (that part that holds the saw plate blank) are too far apart for a 6" one! :D
Thanks,
Dominic
Thanks, Dominic. I use two Japanese ryoba (by Yataiki) for mid-panel cutting, tight spaces, etc.; but hadn't thought of trying dados/sliding dovetails with them. Maybe I will. :)
Pam
Stair Saw Project: finishing up
Hi Gang,
This past week I managed to shape, sand and finish all three stair saw bodies. And as usual I have some photos that documented the process.
After the bodies were sawn to shape, it's now time to clean up those sharp edges and give the handles some pizazz.
I start off with a coarse rasp and knock off the corners.
shaping the body
Then I follow up with a saw maker's rasp and refine the shape.
shaping the body
Then I clean off whatever template paper remains and also smooth out the body a bit
smoothing out the body
After some scraping and some sanding (up to 300 grit) you end up with this:
Sanded stairsaw body
I then repeat the process for the two other stair saws.
Next I apply the first coat of finish. And yes, I used my new favorite, TruOil. :yes:
Applying the finish
I allowed this coat to dry overnight and then sanded it with 400 grit paper. Over the next two nights I applied a second and third coat and repeated the regimen. Today I buffed the finish out and applied a coat of wax. I added my signature to the base of each handle and then the saws were assembled.
Finished Stair Saws
Finished Stair Saws
Finished Stair Saws
These saw plates still need a sharpening, but for saws this size, that shouldn't be too bad.
Thanks for viewing!
See ya around,
Dominic
