New WoodChat!
Miller's Falls Hand Drill Chuck Repair?
Tony - Memphis
I bought a pretty decent #2 on ebay. The chuck is messed up (seller didn't report that). I'd like to keep it. How do I disassemble the chuck? This is the type with the two holes in the top. I measured the holes, but I already forgot the size! I see spanner wrenches out there, but I'm not sure about the size. Looks like somebody has already ben inside the chuck as it looks like they used some pliers to hold it and messed up the knurl a little. This one is for usin' not for lookin' anyhow. Figured many folks here have already been there.
Thanks,
Tony
Re: Miller's Falls Hand Drill Chuck Repair?
Re: Miller's Falls Hand Drill Chuck Repair? *LINK*
I have, in the past, removed two-pin spanner-type nuts by applying a pin punch the right size - in this case, a finishing nail the right size with the point cut off might work - and tapping in the "unscrew" direction. Alternatively, two such pins, one in each hole, and an appropriate pair of pliers or an adjustable wrench ("crescent wrench" is what we call them when I was a kid - like "kleenex" means "facial tissue") closed down to clamp the pins, might make a field spanner. If I recall correctly, these nuts may unscrew counter-clockwise.
Clamping the chuck: if you have the tooling and patience to make a clamp for the shell of the chuck, you might be able to forestall further damage. Take a chunk of hardwood - maple or the like - about 1" by 3" by 4" - and bore a hole in the middle of it the diameter of the chuck shell. Cut down the middle of the length of the piece through the hole and an inch or so past. You want as wide a kerf as you can manage - this is not the time to use your thinnest tenon saw. Power tool blades, like a saber/jigsaw, would be better. Now use this in your vise (I'd use a machinist's metalworking vise if you've got one) as vise jaws to clamp the shell. The kerf allows the hole to close up evenly all around the shell and hold it firmly without crushing it.
You'll find some information on chuck disassembly and cleanup on Wiktor Kuc's website; the most immediately useful article is linked below. You might also be able to score a chuck from him, if yours turns out to be terminally messed up.
http://www.wkfinetools.com/tRestore/miscTools/tuningEggbeater/restEB1.asp
