New WoodChat!
Have a question? Ask Woody!
Cutters for Tongue and Groove Plane?
A. Kapocius
After seeing Uncle Roy Underhill use a tongue and groove plane, I stumbled across (and picked up) one at a MWTCA meeting this morning. Nickel plated (more or less) Stanley 48 in apparently good condition, definitely a user, but it needs two cutters. It needs two 5/16" wide cutters (with an optional 5/8" wide cutter). The Stanley 45 cutters would work, I'm told. Annyone know where I can find some such cutters?
Likely alternative is to pick up tool steel in the proper width, cut to length and grind a cutting edge. The question is then what thickness to order.
Oh yeah, it also has a hole as cast at the top of the tote. Handy if I consider hanging it on the living room wall.
Al Kapocius
Re: Cutters for Tongue and Groove Plane?
Scott Burr in Ben Lomond CA
First off Stanley 45 blades will work, but they will need to be cut down.
Stanley might still make replacement blades for it, check their website.
Jim Reed makes very nice blades. He use to hang out here a lot, but I don't know if he's still around of making blades.
If your going to roll yer own, the blades are ~.125 (1/8) inch in thickness.
Re: Cutters for Tongue and Groove Plane? *LINK*
St James Bay lists them, at a pretty affordable price. This is a company that requires some persistence to reach - I'm told phones are best. Go to "tools," then "Stanley replacement parts," and scroll down a bit. Link below.
Although it's good to know about the parts that Stanley still sells, as they're often the most affordable source for what they do sell, they don't list the No. 48. Still, save this site for future buys: http://www.stanleytoolparts.com/ .
The No. 48's a bit limited in its uses, but not a bad tool to have. You can read some here: http://www.supertool.com/stanleybg/stan7.htm#num48 , and find an instruction sheet here: http://www.tooltrip.com/tooltrip9/stanley/stanmisc/stanmisc.htm (scroll down some).
http://www.stjamesbaytoolco.com/
Ron in Sterling, CT
I bought a set from Jim Reed a couple of years ago. They were ready to go out of the package. He drops in over at Woodnet once in a while.
Ron
Thanks, Guys.
A. Kapocius
Thanks for the help and the links. I already had the Blood and Gore site. Looks like I'll try the tool steel route as more expedient.
Al Kapocius
