We value your privacy.
I am in the market for a Yankee screwdriver to mount a lot of smaller screws i.e., #4 brass flat head screws. A cordless has too much torque and too heavy and, my poor old athritic hands just cannot keep up with the work load using the old slot head hand held screw driver. I am sure I can find someting on Ebay but, was wondering if any models are better than others and, is anything that is in current production also viable. TIA for your recommendations.
Just wanting to make sure you are putting some beeswax on those brass screws before driving them in. You need the smaller version of the Yankee for #4 screws, not sure what # that is (I'd have to look at mine). Buying them on ebay is iffy, sometimes the spring is broke in them. I like finding them at garage sales, full of bits, for 25�.
The coolest screwdriver for little screws like that is the Yankee No. 35, which is small and short and uses the same bit as the 135; but if you can't find a 35, a 135 should be fine. You can get them with and without a return spring. On the 35 and 135, the return spring is fairly gentle (way stronger on the larger drivers), and I would think it would be a good thing for someone with arthritis.
Lee Valley sells a screwdriver like the 135, see the shorter one in the link below. You can also get bits from them that fit the Yankee drivers, if you find a driver lacking the right bits; they also sell an adapter that will allow the use of hex bits.
Garrett Wade sells a German version that takes hex bits, but it's pretty pricey; it would cost you more to get their short driver than to buy a Lee Valley driver AND an assortment of bits.
In my observation, Yankee drivers are fairly bulletproof. I've only ever seen one or two that were broken, and, as long as you lubricate them, they seem to last.
You probably already know this, but I'll mention it: in addition to the beeswax that Moses mentions, the classic way to avoid bunging up the slots on a brass screw is first to drive a steel screw of the same size and length into the hole, to "tap" the hole. The brass screw then goes in quite happily, with less chance of damage. Also, if you have trouble finding beeswax, paraffin wax or the waxy material used in those rings that seal toilets to the floor (new, not used ) will work too.
It's for cire perdue casting and encaustic art. Softer and less toxic than microcrystalline carving waxes, it's easy to build forms I'm after in some glass vessels. Imparts the silky finish of late Art Nouveau and early Art Deco p�te de verre, where asbestos added to moulds enhanced refractory qualities. After burnout it can be mixed with damar crystals and pigments to make encaustic medium and colors. Many other uses, too, but that's where the bulk of it goes.
As for wood, I like the dry satiny look of beeswax rubbed on with a bit of water (no emulsification, no solvents) and lots of effort, and the pale highly-filtered Dadant beeswax (no chemical bleaching) is my favorite for all uses.
My all time favorite finish for any wood items that come in contact with food is mineral oil and beeswax.I melt the wx in a double boiler and then add the mineral oil till it`s where I like it.Not too thick to be a problem applying it yet not too thin to buff out.It varies as to what I`m working on.
It is a pleasure to melt into turnings as the friction does all the work and takes only seconds to get results and a finished product.I`m notoriously impatient.
I have used this same finish on all my wood planes to good effect.I take the crud encrusted plane to the sink and scrub it using Simple Green and water then rinse.
The SG cuts the crud but leaves the patina.
I can usually pop any paint spatter off with a butter knife first and even if I have to scrape the paint then the scrubbing with the SG and a non abrasive scotchbrite pad will even things out and blend any light areas.The body gets set aside near the woodstove to dry and then the oil/wax is applied while the wood is warm and then buffed off with an old T shirt.
I soak any rusty metal parts in vinegar while working on the wood to loosen the rust and then scrub them with a wire brush under running water and set them on a rack on top of the woodstove to dry completely.
Beeswax also makes an excellent temporary adhesive that can be released with a the help of a heat gun or a couple seconds in the microwave.
It` will also improve your grip when applied to either your hands or the tool.Be careful as long term use can bring on blisters.
This time of year I set aside some of the oil/wax and thin it further with some of my wife`s herbal oils(olive oil infused with healing herbs).It`s a favorite with the entire family for chapped or cracked skin.
I get all my wax from local beekeepers.I have to be quick in order to beat the candle makers though.
The company David linked to supplies beekeepers and has everything you may need to send you down yet another slippery slope.Get the free catalog and prepare to be sucked in.
"Beeswax also makes an excellent temporary adhesive that can be released with a the help of a heat gun or a couple seconds in the microwave."
I'm always using beeswax this way. With all the encaustic I do, a heat gun practically stays in my left hand. An electric griddle is my palette. I can keep the encaustic hot while I move it from the palette to the painting surface. Which brings me to the point: damar crystals added to beeswax improves its fixturing properties, especially when applied hot. Great stuff. Far more forgiving than pitch, dopping wax or even shellac. Moves easily, though, so best for repositioning or non-critical things.
"It will also improve your grip when applied to either your hands or the tool. Be careful as long term use can bring on blisters."
Chasers hammers are traditionally covered in beeswax, allowing you to lighten your grip. It's also wonderful for jeweler's saw frames. A more relaxed grip pays ergonomic and technical dividends. And you're right, it'll pull skin layers loose and generate juicy blisters if you use it incorrectly or too long. But with my carpal tunnel syndrome, I've gotta have it.
By the way, there's a lot to learn about prehension aids such as beeswax. I'm rereading "Human Hand Function". The chapters on active haptic sensing, prehension, and non-prehensile skilled movements are truly thought provoking. Superb scholarship.
