New WoodChat!
Dovetail layout
Dovetail layout
Dovetail layout
John Pappas
Bill Tindall recently posted a message about laying out dovetails using a jig he had developed, and described how to use it. Because I use a similar jig, I would like to take the liberty to add some of my method to his fine post.
The concept of my jig is the same, but it is adjustable. Just loosten the knurled knob and slide the brass template into the desired pin size.
In addition, I use a slightly different method to measure and layout the pins. It avoids the need to align the jig to the center of a pin. I first layout the pin on the left, and then look at the remaining space as tail/pin sets. By thinking about tail/pin sets, I am able to "walk" down the board with my thumb and get an idea of how many sets I will lay out. In diagram A there are four sets of tails pins. The extended lines highlight these sets. Note that these lines represent the right hand edge of the tail/pin set
Diagram B shows the steps I take. I first mark the pin on the left. Then I measure the distance from that pin to the right edge of the board and divide the space into the desired number of tail/pin sets.. I use a metric ruler to simplify the math. In this case the distance is 96mm. I divide by four and mark off 24mm increments. Those marks represent the right edge of the pin. I then use the jig to layout the pins as shown in diagram A. One other note; this method works whether you layout pins first of tails first.
Re: Dovetail layout
Re: Dovetail layout
John Pappas
Oops, the jig
